  • June 18, 2025, 12:34:02 AM
Author Topic: meowww  (Read 1235 times)
Offline roger
meowww
« on: August 04, 2009, 07:19:14 AM »
any body have an f-14 tom cat profile? H^^
Offline Mike Keville
Re: meowww
« Reply #1 on: August 04, 2009, 09:46:08 AM »
Carstens (FM) has plans for Vic Macaluso's 56"-span full-fuselage stunter.  You could easily turn one into a profile.
Online Trostle
Re: meowww
« Reply #2 on: August 04, 2009, 11:19:22 AM »
It might look sort of "different" trying to put two vertical tails on a skinny profile fuselage.
Maybe "intereting" might be a different way to describe it.
Offline roger
Re: meowww
« Reply #3 on: August 06, 2009, 02:58:38 PM »
 LL~
Offline Clancy Arnold
Re: meowww
« Reply #4 on: August 06, 2009, 05:30:17 PM »
It should not be hard.  The stab should be full size including the area inside the scale fuselage so set the rudders on the stab at the scale positions.
Clancy
Clancy Arnold
U/Tronics Control
