  • July 08, 2025, 08:30:37 PM
Author Topic: AG Cat Duster.  (Read 4525 times)
AG Cat Duster.
« on: May 25, 2018, 11:33:11 AM »
For anyone interested in scale or semi-scale,
I've placed a few more photos of my Ag Cat Duster, the Build over at CFC Graphics vendor's corner.
Take a look!
Charles
Online Paul Smith
Re: AG Cat Duster.
« Reply #1 on: May 25, 2018, 03:06:55 PM »
If that's your model you will get good static points.
Re: AG Cat Duster.
« Reply #2 on: May 26, 2018, 10:40:00 AM »
Good one.
Do you think anyone really understands what you're implying?  LL~ LL~
Re: AG Cat Duster.
« Reply #3 on: May 27, 2018, 06:38:51 AM »
All things considered,
Cleaning spent fuel is going to be a pain with two wings and the Jen .57.
I'm considering switching over to Electric while I'm in the early stages of the build.
Maybe.
CB
Edited for photo.
« Last Edit: May 27, 2018, 10:45:04 AM by Avaiojet »
Re: AG Cat Duster.
« Reply #4 on: May 27, 2018, 02:24:56 PM »
Maybe.
CB
Edited for photo.
    You haven't had to wipe down an airplane yet, so why would this one be any different?
  Just askin'.
Offline John Rist
Re: AG Cat Duster.
« Reply #5 on: May 29, 2018, 03:36:07 AM »
The ease of throttle control alone makes electric scale a good deal!  Wet RC engines run great wide open and have a good idle but tend to load up and quit at mid range.  A dead engine in the middle of a flight is a zero score.  Ask me how I know.   y1
Online Paul Smith
Re: AG Cat Duster.
« Reply #6 on: May 29, 2018, 07:53:29 AM »
Zooming into photo shows the tie-downs, so it must be the real thing, unless you modeled them too.
One real deal-breaker is the uncowled radial engine.  Thar would take a lot of work for very little payback.
Re: AG Cat Duster.
« Reply #7 on: May 29, 2018, 09:48:00 AM »
John,
Thanks for the reply.
Yes, I believe I'll go electric not only for clean up but because biplanes generally need a bit of weight in the nose.
I've never had an R/C engine act up. Carb always worked well if adjusted properly.
Paul,
I really don't know how to reply to you, you can understand that, I'm sure.
Yes, I've owned a few aircraft over my GA participation years, last being a Lake LA-4 200T.
Berkeley actually made a kit of this aircraft, so did a few others.
The engine will be an issue. At the time I'm not sure how I'll treat this because there's so much of it showing?
Some of these dusters had cowling rings. An option.
Charles
Offline James Holford
Re: AG Cat Duster.
« Reply #8 on: May 31, 2018, 06:19:10 AM »
Our Ag Cats down here dont use Radials. In-lines with a cowl.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: AG Cat Duster.
« Reply #9 on: May 31, 2018, 06:47:51 AM »
James,
This particular Grumman aircraft I'm modeling was built in the early 70's. A guess.
Many have engine upgrades and both types are still in use today.
Charles
Re: AG Cat Duster.
« Reply #10 on: May 31, 2018, 06:48:29 AM »
Thsts the ones we have yep
Jamie Holford
Lafayette, La
AMA #1126767
Online Paul Smith
Re: AG Cat Duster.
« Reply #11 on: May 31, 2018, 01:04:07 PM »
Free Flight scale gives A LOT of complexity points for things like biplanes, multi-engine and pushers.
CL scale has none of that.  They don't give anything for complexity, but take off points for things that aren't quite right.  So in the CL scale contest world, simple wins.
Re: AG Cat Duster.
« Reply #12 on: May 31, 2018, 01:59:46 PM »
Those "in line" engines are tubines.  Notice the huge exhaust pipe exiting the cowl.  We went to those way back in the late '70's just before I had to leave the ag business.
Re: AG Cat Duster.
« Reply #13 on: June 01, 2018, 09:12:23 AM »
"Good" Will Hinton,
Will!
Thanks for the reply.   #^
I have this model started also. One of the reasons I want to keep that radial.
Charles
Re: AG Cat Duster.
« Reply #14 on: June 01, 2018, 07:21:40 PM »
Wow, on floats?  I bet that could become a real bear if loaded heavy on a high density altitude day!  Never saw one like that.  Thanks for posting, Charles.
Re: AG Cat Duster.
« Reply #15 on: June 12, 2018, 04:00:04 PM »
"Good" Will Hinton.
Will, I just saw your reply.
You know I have interest in unusual designs.
Thicker wing and a longer take off run, like scale, and the model will fly just fine.
It does have wheels under those floats, so tarmac flying will be possible.
I have to sell some models to continue with current projects.
Charles
Offline Robert Whitley
Re: AG Cat Duster.
« Reply #16 on: June 13, 2018, 07:37:34 AM »
They use ag-planes on ampib floats for forest fire fighting.
Re: AG Cat Duster.
« Reply #17 on: June 13, 2018, 01:42:03 PM »
Robert,
Yes they do. One aircraft is the Fire Boss which I have a build thread on.
The Fire Boss is on floats.  Check out the Fire Boss build.
Charles
I added the link.
https://stunthanger.com/smf/cfc-graphics/air-tractor-at-802-fireboss!/
« Last Edit: June 13, 2018, 04:01:07 PM by Avaiojet »
Re: AG Cat Duster.
« Reply #18 on: June 13, 2018, 08:16:04 PM »
Hi Charles,
Thanks for the link.
It looks quite interesting and I’ll have to explore it in detail when I get a bit more time available.
