  • July 18, 2025, 06:17:23 AM
Author Topic: Venturis for the Magnum/ ASP 15 available again!  (Read 12287 times)
Offline bill bischoff
« on: December 28, 2013, 07:30:54 PM »
I have venturis for sale to fit the Magnum and ASP 15. They are blue anodized aluminum, .250" bore, and comply with the new Dallas Sportsman Goodyear rules.They are drilled for Supertigre/ RSM or other 4 mm/ 5/32" spraybars.
$10.00 each. I also have RSM needle valve assemblies to fit. $10.00 each. $3.00 postage per order in the US. Send me an email or a PM.
Bill Bischoff
10/1/14 Now back in stock!
« Last Edit: October 01, 2014, 09:30:01 AM by bill bischoff »
Offline Wayne J. Buran
Re: Venturis for the Magnum/ ASP 15
« Reply #1 on: January 08, 2014, 07:38:31 PM »
Bill, can you give me an idea on which APC prop you are running and any other details about the project, plane size, motor performance aircraft, whatever.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #2 on: January 09, 2014, 10:29:58 AM »
We use the APC 6.5x5 and 6.5x5.5 props. Planes are typical AMA Goodyear size, 22 oz "ish". Performance on .015x52 stranded lines should be about 80 mph, engine RPM 19,000 "ish". My plane is the "BooRay", but there are lots of suitable designs for Goodyear. Flying Models published the taper wing Cassutt, Model Aviation published the Zipper and Li'l Quickie, Model Airplane News published the Rickey Rat, and the R.S. Hirsch books have dozens of 3 views that could be scaled up. Avoid designs with low wings, wing mounted landing gears, and unusually long or short noses.
« Reply #3 on: January 10, 2014, 06:14:43 PM »
Bill, thanks for the information. Very helpfull. Thanks.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
« Reply #4 on: September 02, 2014, 09:51:56 AM »
A new batch of venturis is coming soon. Watch for a post when they are ready.
« Reply #5 on: September 02, 2014, 03:58:31 PM »
Would like to see a bigger pic of the BooRay as I have built one for big goodyear. What is the aspect ratio of the wing?
« Reply #6 on: September 02, 2014, 07:21:14 PM »
I never bothered to calculate the aspect ratio...
Offline don Burke
« Reply #7 on: September 02, 2014, 07:44:04 PM »
One way of calculating A/R is Spanē/area. Span is on the boo.jpg, (I'm too lazy to break out the slide rule). I believe midgets area is 66 sq ft.
don Burke AMA 843
Menifee, CA
« Reply #8 on: September 03, 2014, 09:36:04 AM »
Must be a different version, my BooRay has a straight wing.
Offline don Burke
« Reply #9 on: September 03, 2014, 10:04:07 AM »
Many of the midgets were built with various wing configurations.  Most of the homebuilts were based on Cassuts.
don Burke AMA 843
Menifee, CA
« Reply #10 on: September 09, 2014, 10:06:44 PM »
BTW, I have a mod for the ASP 15 that will guarantee an increase in power so tremendous that it will send the crankshaft out the front of the motor.
Offline BillLee
« Reply #11 on: September 10, 2014, 03:42:22 AM »
What event would you use it in, Walt?
Bill Lee
AMA 20018
« Reply #12 on: September 10, 2014, 08:45:24 AM »
Whatever event that $43 motor fits in.
Offline BillLee
« Reply #13 on: September 10, 2014, 02:57:24 PM »
Well, your modified motor wouldn't work for Sportsman GY as it's been defined.
"Engines must be of stock configuration only. No material may be added or removed (except through
normal wear and use), except the engine mounting holes may be enlarged or elongated. No non-stock
parts may be substituted except for the glow plug, venturi, needle valve assembly, ball bearings,
gaskets, screws, prop washer and prop nut."
And that, after all, WAS the context of the OP.
But I WOULD like to know what mod you mean. Care to share?
Bill Lee
AMA 20018
« Reply #14 on: September 10, 2014, 03:10:59 PM »
You want a guarantee that your engine will break? Let me fly it!  %^@
« Reply #15 on: September 10, 2014, 03:50:28 PM »
Oh so only parts you guys make are allowed?
« Reply #16 on: September 10, 2014, 05:57:37 PM »
I provide venturis and needle assemblies as a convenience. You are not required to use mine. Anything that meets the rules is allowed.
Hey, we've managed to steer this back to the original topic of venturis!  #^ #^ #^
Offline BillLee
« Reply #17 on: September 10, 2014, 09:06:24 PM »
You going to share a speed secret?
Bill Lee
AMA 20018
Offline Mike Callas
« Reply #18 on: September 11, 2014, 01:11:35 PM »
FYI Bill
I bought a Magnum, ordered your venture and used it on my OS 15. Works great!
Now I need another one for the Magnum.
« Reply #19 on: September 13, 2014, 09:21:28 AM »
Mike, I received your payment, but I am out of venturis right now. More are in the works. I will send your order ASAP.
« Reply #20 on: September 13, 2014, 03:37:13 PM »
It was more of less just joking around, what good does it do to get more power when the engine blows up. I've modified lots of ASP engines when they first came out and I think almost all of them twisted the crank in half. Stopped modding the crank itself and just did other mods and the cranks still broke. Finally realized the shaft in the ASP line is very soft. As for the mod, anybody that knows engines can look at an ASP and it jumps out at you, just don't do it or the crank will come out the front.
Offline BillLee
« Reply #21 on: September 13, 2014, 08:29:04 PM »
Oh, my......  HB~>
Bill Lee
AMA 20018
Re: Venturis for the Magnum/ ASP 15 available again!
« Reply #22 on: October 01, 2014, 09:30:33 AM »
Venturis and needles in stock again 10/1/14.
« Reply #23 on: May 07, 2015, 12:37:53 PM »
  H^^ Just a reminder, I still have venturis and needle assemblies in stock.
Offline Phil Krankowski
« Reply #24 on: May 07, 2015, 08:09:03 PM »
Will that fit the AP hornet 15?
http://hobbyking.com/hobbyking/store/__25464__AP_Hornet_0_15_Two_Stroke_Glow_Engine.html
Its just going onto a jr ringmaster or something similar.
Phil
« Reply #25 on: May 08, 2015, 12:44:36 PM »
I don't know about that particular engine, but these venturis fit a 10 mm hole in the engine.
« Reply #26 on: May 08, 2015, 01:01:06 PM »
I just measured.  .354 inches, so 9mm, which is a no-go.
Thank you.
Phil
