  • June 18, 2025, 12:13:20 PM
Author Topic: Newest Super Slow Rat  (Read 10261 times)
Offline bill bischoff
« on: September 07, 2014, 04:09:42 PM »
This is my new super slow rat, ready to be test flown. Brodak 25, APC 8x6 prop, internal line connections, internal pushrod. Klass Kote epoxy paint, Fibafilm (Micafilm) on the wings, glass cloth and epoxy on the wood. 25.5 oz.
Offline don Burke
Re: Newest Super Slow Rat
« Reply #1 on: September 07, 2014, 05:05:40 PM »
Very nice!!!!!!!
don Burke AMA 843
Menifee, CA
Online Motorman
« Reply #2 on: September 07, 2014, 07:17:33 PM »
I like it, all the angles seem to match. What does it weight?
« Reply #3 on: September 07, 2014, 08:04:34 PM »
Looks fast and great.   Is there a set of plans available.
« Reply #4 on: September 07, 2014, 08:53:50 PM »
Doc, I have enough info for you to build one, but no formal plans. Except for the built-up wing instead of a foam wing, it is the same basic airplane as the yellow and blue one Mike Greb has.
Look closely young grasshopper, the answer you seek is contained within.
Offline BillLee
« Reply #5 on: September 08, 2014, 05:13:36 AM »
Looks like a quote from a Jim Butcher novel!  ;D
Bill Lee
AMA 20018
Online Motorman
« Reply #6 on: September 08, 2014, 09:30:32 AM »
How do you get the fuselage on over the pushrod, is there a panel you install after the wing joint is made?
« Reply #7 on: September 08, 2014, 10:58:31 AM »
The inboard side of the fuselage is slotted for the pushrod and control horn, and inletted for a 1/32" ply plate to cover everything up after the wing is glued into the fuse. Since it was a straight shot, I was able to use a simple music wire pushrod.
(Picture added 1/12/15)
« Last Edit: January 12, 2015, 09:34:32 AM by bill bischoff »
Offline don Burke
« Reply #8 on: September 08, 2014, 11:16:48 AM »
The inboard side of the fuselage is slotted for the pushrod and control horn, and inletted for a 1/32" ply plate to cover everything up after the wing is glue into the fuse. Since it was a straight shot, I was able to use a simple music wire pushrod.
iMO the slot in the fuse COULD be covered with a thin CF strip, duplicate on the not slotted side and you'd have a "PITMAN CATCH WHIP PROOF" aft fuselage!!!!
don Burke AMA 843
Menifee, CA
« Reply #9 on: September 08, 2014, 12:09:02 PM »
The fuselage has 2 full length 3/16" x1/2" spruce stiffeners. This has served me well. (Having said that, this one will probably break!)
« Reply #10 on: October 13, 2014, 01:16:39 PM »
Won its first race (out of a field of 6) with a 5:23!
Also won its second race with a 5:23!
« Last Edit: February 16, 2015, 11:49:35 AM by bill bischoff »
Offline BillLee
« Reply #11 on: October 13, 2014, 02:59:59 PM »
The plane's name is
"Split Pea Soup"
 ;D
Bill Lee
AMA 20018
« Reply #12 on: October 13, 2014, 03:03:59 PM »
From Johnny Clemens himself:
Q)What's the difference between mashed potatoes and pea soup?
A)Anybody can mash potatoes!
Offline Jim Carter
« Reply #13 on: January 02, 2015, 06:02:11 PM »
Thoroughly impressive Sensei!!  Thoroughly impressive!!  From a lowly grasshopper .... how do you make your tanks?  How much fuel do you carry?  What is the maximum size tank allowed?  Where do you get your fuel shutoffs?  I humbly and anxiously look forward to your enlightened teaching cauz' I jus' don't know 'dis stuff!!   ;D
« Reply #14 on: January 02, 2015, 07:54:56 PM »
For tank details, see my post called "new SSR nearing completion" on page 2 of the racing forum. The tank is about 1.1 oz. The maximum size allowed is 2 oz. You are not allowed to use shutoffs in this event except in an emergency, so your tank needs to be the right size. My post details how to "get two different size tanks for the price of one". We use this short-tanking ability all the time with good results. I have included some info on a super simple shutoff for sportsman Goodyear that can also be installed on a SSR. I have never needed to shut off to save a plane in this event, but have tripped the shutoff accidentally before. For that reason, there isn't a shutoff on my new airplane.
Online Motorman
« Reply #15 on: February 15, 2015, 10:39:28 PM »
How big is the tail, looks like 15% ?
« Reply #16 on: February 16, 2015, 11:46:26 AM »
50 sq. inches.
Online Motorman
« Reply #17 on: February 18, 2015, 12:25:38 PM »
Ah 16.66%, do you find it grooves better with the tail up high or is that done just for the internal push rod. How much off set in the stab?
« Reply #18 on: February 18, 2015, 10:03:08 PM »
The stab is above the center line to keep the tips from dragging the ground. What do you mean by "offset"?
Online Motorman
« Reply #19 on: February 19, 2015, 09:14:28 AM »
How far above the thrust line.
Offline BillLee
« Reply #20 on: February 19, 2015, 12:00:27 PM »
Mounted above the thrust line also gets it out of the downwash from the wing, makes the stab/elevator more effective.
Bill Lee
AMA 20018
« Reply #21 on: February 19, 2015, 05:24:31 PM »
1 1/8" from bottom of stab to thrust line.
