  • July 18, 2025, 03:58:55 PM
Author Topic: MOUSE RACING PLANS?  (Read 20993 times)
Offline LARRY RICE
Re: MOUSE RACING PLANS?
« Reply #50 on: February 04, 2008, 09:09:52 AM »
WOW! No gun shots. I was sure that I would ruffle some feathers,.......I like this site!
        I will check these sites out Thank You
Larry
Willis Swindell
« Reply #51 on: February 04, 2008, 01:13:22 PM »
I could box up my Sweet Pea and send it for you to copy
Willis  H^^
Offline LARRY RICE
« Reply #52 on: February 04, 2008, 02:52:49 PM »
I think that the Sweet Pea is the plane that is floating around in that empty space between my ears. While we have started a project that will give us good coverage of the Mouse racers of today I think a Sweet pea will be a better seller. Yes I would like either plans or the plane to copy. Was it Dumas who kitted it?
Thank you
Larry
Willis Swindell
« Reply #53 on: February 04, 2008, 05:24:54 PM »
Larry
I just had a three view drawing and scaled it up.
Willis
Willis Swindell
« Reply #54 on: February 16, 2008, 04:53:54 PM »
Larry the Sweet Pea is on its way. I just want to say something about the wing, it looks warped but it’s not. It has sort of a Clark Y airfoil at the fuselage and symmetrical at the tips. This gives it enough lift to fly level for more speed  and doesn’t climb into the wind. I have used this airfoil in all my racing and speed planes. I think in my opinion this wing is faster then a symmetrical wing. Joey Mathison and I tend to agree to disagree on this type of wing but it always worked for me.
Willis
Offline Joey Mathison 9806
« Reply #55 on: February 16, 2008, 05:25:11 PM »
while it it true that the negative wash out at the tips makes for a very stable flying plane it does not suit my needs for todays style of flying fast mostly due to the fuel restrictions. on 10%fuel the motors have a hard time warming up hince the need to fly high for about the first 5 laps of a speed run this seems to warm them up and burn all the fuel that i am trying to make it burn. check d speed results for the last 5 years at the nats to see if it works. H^^
200 mph man ama#9806 joey mathison
Willis Swindell
« Reply #56 on: February 16, 2008, 05:47:10 PM »
Joey
Can’t top The records. I remember Jimmy didn’t need a wing at all with you flying. Remember your mouse 2, TD powered wing at Winston-Salem AAAA? It was so fast when the engine cut off we just stood there with our mouths hanging open until we realized the plane had landed.
Willis  S?P
« Reply #57 on: February 16, 2008, 06:19:13 PM »
of all the racing we did i think that the 1/2 a stuff was by far the most fun.
Offline Mike Greb
« Reply #58 on: October 04, 2014, 05:04:54 PM »
Bump.    Is there a source for the Streaker 5 plans?  I did a google search and the only site that  i found seems to be a adware site.
Offline PaulGibeault
« Reply #59 on: November 19, 2014, 08:01:15 PM »
Hi Mike<
Try Paul Gibeault: Detailed Streaker plans.  $10 post paid. Contact pgibeault at shaw.ca  if you're still in need.  Good luck!
