  • July 17, 2025, 08:34:02 PM
Author Topic: Modified Brodak Super Fly SSR  (Read 6853 times)
Offline bill bischoff
« on: February 22, 2015, 01:38:16 PM »
I am in the process of building a modified Brodak Super Fly, "just because". I shortened the wingspan by 5 inches, added fixed flaps with a 2" root chord, and replaced the wing tips with solid block tips. I also shortened the nose 1/2" and only used a single 1/2" thick cheek cowl. I changed the stab and elevator for cosmetics, but used the original wood. There are also a few structural mod's, like a carbon fiber nose doubler and a beefed up center rib and bellcrank mounting. I also used a 3" bellcrank. I don't know if it will be any faster, but to me it looks more "right". Time will tell.
Offline Jim Carter
Re: Modified Brodak Super Fly SSR
« Reply #1 on: February 22, 2015, 03:47:33 PM »
Hey Bill!  Looks nice!  I've got one that I built "stock" for the Fox Racing but was told that it was illegal and that's a darned shame!  I like it and all I've got is a box stock Fox .35.  Are you build yours for a particular class/category??  I've got a second one, here in the box that I was thinking about mounting my Rossi 40 on jut for the heck of it but there's no real purpose for it is there?
« Reply #2 on: February 22, 2015, 03:53:00 PM »
Bill, I think it looks a lot better than the kit.   Now I would like to know who said it was illegal for Fox Racing.  Maybe Fox Berg which is another event.
« Reply #3 on: February 22, 2015, 07:34:19 PM »
Mine is built for Super Slow Rat and will use a Brodak 25. I don't know why anyone would say it is illegal for NCLRA Fox Racing. Like Doc said, it wouldn't be legal For Fox-Goldberg racing, but that is a different event.
Offline Jim Carter
« Reply #4 on: February 23, 2015, 08:47:01 AM »
Greetings John and John!  I stand corrected, I should have said Foxberg.  It had been my hope to go to Brodak's to have some fun but that was the year it was not allowed thus I still have it hanging on the rack.  I've never had opportunity to participate in "NCLRA Fox Racing".
Offline Balsa Butcher
  • High Desert Flier
« Reply #5 on: February 23, 2015, 11:01:51 PM »
Looks fast Bill. Wing has sort of a "Flite Streak" vibe to it. Ought to whip better than the stock SF. Send a pic to John Brodak. Maybe he can come out with a "Super Fly Mk. II" kit. I'd buy one.  ;D
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #6 on: February 24, 2015, 08:17:22 AM »
You could put an LA25 and a shutoff on it and fly the 100 mile race on Thursday morning at The Brodak.
Offline Jim Carter
« Reply #7 on: February 24, 2015, 09:28:34 AM »
Thanks Paul, you're correct and I can accept and appreciate that.  Would you believe .... out of my "stable" of engines one of the engines I've never run or owned is an LA of any type!  I do have a couple of the older Max 25's but I know, unfortunately, they're not acceptable and with a fixed income and very tight budget I'm not able to justify spending for the sake of spending.  C'est la vie!
« Reply #8 on: February 24, 2015, 11:27:12 AM »
Why isn't the Max .25 eligible?    Just came from the NCLRA site rules for SSR.   Only engine not allowed is the Big Mig .25.
Offline Jim Carter
« Reply #9 on: February 24, 2015, 01:34:34 PM »
  Hi Doc!  My comments may be confusing as I'm considering two different events at the Brodak event 1) Foxberg which specifies Fox.35, Brodak .25 and LA .25 only; 2) the 100 mi. race which specifies the LA .25 only.  I may well be mistaken because I missed a post or something but I've tried to follow as best as I could and here's what I found based upon what I've seen on this and another forum:
http://stunthanger.com/smf/index.php/topic,38164.0.html
Stock LA 25 on suction
Outboard fuel tank, shutoff recommended by not required
24" prop nut to hinge
300 square inches of wing at least 1" thick.
59'-6" minimum line length .015' 7-strand lines.
House-provided 10/10/10 fuel bought from Ritch's Brew.
The Brodak web site specifies airframes that can/will be permitted but the rules for the 100 mile race seems to be allowing a somewhat more liberal selection of planes.  In any case I'm definitely NOT complaining I just want to have the right stuff at the right time if I can and if not .... I'll set back and enjoy or pitch in to help someone else if I can.  I regret any confusion I may have brought about.
Offline BillLee
« Reply #10 on: February 24, 2015, 03:38:34 PM »
The one rule from Paul's Brodak LA race that will rule out many SSR model is the 24" minimum length. The SSR rules specify 22" and many/most(?) are built to that specification.
Bill Lee
AMA 20018
« Reply #11 on: February 24, 2015, 09:40:43 PM »
So we now have slow rat, super slow rat, Fox race slow rat, Brodak slow rat and Canadian slow rat.
« Reply #12 on: February 25, 2015, 08:51:40 AM »
The Toronto-rules LA 25 Sport Race started or with just LA25's and ARF Steaks.  But there was a lot of resistance to buying or building the 'Streak, so the rules-makers backed down and used the long-standing 300 squares and 24" length.
I don't see either of these as much of a barrier.  I need at least 24" of length to make the plane balance properly.  If I made 22" fuse I'd have an ounce of lead in the tail.
It's a ONE engine event.  The engine is inexpensive and readily available.  For a while they "grandfathered" the Fox 35 Stunt.  I tried to run my best Fox racing engine on the theory that 40% more displacement was a lot to give up.  But one race against LA 25's was all the schooling I needed.
Offline BillLee
« Reply #13 on: February 25, 2015, 12:48:03 PM »
Nonsense.
Bill Lee
AMA 20018
Offline Wade Bognuda
« Reply #14 on: February 25, 2015, 01:10:49 PM »
What diameter wire did you use on your leadouts? Thanks.
« Reply #15 on: February 25, 2015, 04:03:54 PM »
.032 solid. The ends are built to be the line connectors.
« Reply #16 on: March 14, 2015, 05:21:51 PM »
It's basically done except for a couple small details. CG about 1 " from LE, weight 22.5 oz. I decided I don't like the look of the bubble canopy. Should have gone with a turtle deck.
Offline David Ruff
« Reply #17 on: March 16, 2015, 04:28:25 AM »
So if I build the Super Fly and use an OS .25 LA, I am legal at Brodak?
My club is going to have a race event...not many rules other than engine size.  But I would like to build something legal for something....
Retired Army
