  • June 29, 2025, 01:21:21 AM
Author Topic: K&B .29 , or McCoy .29 substitutes ?  (Read 3668 times)
Offline Rob Killick
« on: November 23, 2011, 09:39:33 PM »
Gentlemen ,
I was thinking about building Cal Smith's "Ole Slippery" and was wondering what might be a suitable (modern) engine replacement for the K&B .29 , or the McCoy .29 engines ?
Thanks ,
Rob Killick
Rob Killick , MAAC 33300
Offline Les Akre
Re: K&B .29 , or McCoy .29 substitutes ?
« Reply #1 on: November 24, 2011, 12:12:19 AM »
Hello Rob
The Brodak .25 is  good choice. The O.S. 25 LA and FP are good choices too. Then there is the TT GP .25, the Brat .25 and .28. Even the Norvel .25 "Big Mig" version will work as will the "AME" ball bearing version. I've used a GMS .25, and am currently developing an Irvine 25 Mk3 for "B" tr use.  The plain bearing .25's will get you at minimum, as much speed as the old McCoy's and K&B's had "in the day". The ball bearing engines, even more.
Les
Offline Rob Killick
« Reply #2 on: November 24, 2011, 09:08:37 AM »
Thanks Les ,
I appreciate the info .
Rob K.
Offline Terrence Durrill
« Reply #3 on: November 29, 2011, 01:24:34 PM »
Rob, if you happen to reconsider and would like to fly Cal's "Ole Slippery" as Cal designed and flew it, the K&B .29 greenhead is almost always available on Ebay and is a very user friendly and powerful old time engine.  I have eight of them myself, some in like new condition.  Seven of these came from Ebay sellers, several at between $22.00 and $30.00 plus shipping..................The K&B greenhead .29 was my first "big engine" back in 1954 and is one of my favorites along with the Fox .29 and Fox .35 stunt.  It was originally mounted on a Guillows Trixter B-C profile stunter.............those were the days!............TDurrill    y1    H^^
Here are two examples:             http://www.ebay.com/itm/140649067739?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
ALSO: Check out the following item currently on Ebay.
http://www.ebay.com/itm/VINTAGE-1947-1948-K-B-TORPEDO-29-GLOW-ENGINE-AWESOME-NO-RESERVE-/170735955254?pt=LH_DefaultDomain_0&hash=item27c0a7ed36
« Last Edit: November 29, 2011, 05:14:48 PM by Terrence Durrill »
Offline Rob Killick
« Reply #4 on: December 01, 2011, 03:18:41 PM »
Thanks Terrence ,
That was my initial goal , was to build it as the original.
I see the second E-Bay listing calls the engine as a glow engine , but I see a spark plug hanging out of the head !  ::)
I might have to try the "Bay" and see what I come up with .
Thanks !
Rob K.
« Reply #5 on: December 01, 2011, 04:13:25 PM »
Thanks Terrence ,
Rob K.
Hi Rob,
I haven't looked but it could easily be a Champion GLOW plug.  I have several of them and a few other companies (Veco did) also made glow plugs with the porcelain insulators.  If it doesn't have the points assembly, etc., showing then it'd probably just one of those glow plugs.
Big Bear
Offline Rob Killick
« Reply #6 on: December 01, 2011, 05:16:08 PM »
Hey Bill !
Shows you what I know  :-[
I thought it a bit odd there were no points/spark advance on that crankcase .
Thanks for pointing out the glow plug  ;D
Rob K.
Offline Thomas Wilk
    • Tom Wilk's old mag plans on CD
« Reply #7 on: December 02, 2011, 08:19:37 AM »
those old glow plugs are sought by engine collectors.  a local car club member has a spark plug collector and ahs a few ib his collection.
Tom
« Reply #8 on: December 02, 2011, 08:24:33 AM »
Tom
Hi Tom,
I have picked up quite a few of the old Champion and Veco glow plugs over the years.  I have a Champion in my Veco/Allyn .35 which I hope to use in OTS sometime next year. ;D  A few are still new in the box.  Now, they are getting pricey!
Offline dankar
« Reply #9 on: December 05, 2011, 09:40:42 PM »
Webra .25GT/.28GT/ OS .25F/.28F. I have an ole Slipery finished with Enya .29 plain bearing.  Have a Abel Mabel with OS .25F and Challerger with OS .25F. The newer design and made for modern engines and quite a bit more complex, but ya need to finish. Dan
« Last Edit: December 07, 2011, 03:15:40 PM by dankar »
Offline BillLee
« Reply #10 on: December 06, 2011, 05:33:27 AM »
I have a couple of NIB Webra 28GT for sale. $125 plus shipping if anybody is interested.
Bill Lee
AMA 20018
« Reply #11 on: June 13, 2012, 08:56:04 AM »
A "little" late, but if you haven't gone with a K&B .29GH then the Webra .28GT would be my second choice.  VERY strong engine!  (I have run at least three of them w/no problems at all)
A "standard McCoy .29 Red Head would never be my choice for any racing or speed plane.  The earlier ring rear intake versions were fairly quick, though, and the ring will last much longer than the piston/sleeve in the later Red Heads.  One lean hot run and it can easily be toast.
BIG Bear
RNMM/AMM
Offline rustler
« Reply #12 on: June 13, 2012, 02:37:04 PM »
Over here in England one favourite engine for this sort of thing is the Enya IV, 5224 on c/case. Comes in BB and bushing versions.
Ian Russell.
