  • June 27, 2025, 04:25:02 AM
Author Topic: repairing the Glowbee Fireplug  (Read 1291 times)
Offline Fred Quedenfeld jr
« on: December 21, 2012, 01:14:40 PM »
Any one out there fix these I have 2
the batteries are good but no juice to the glow plug
can the  variable pot be replaced???
Thanks Fred Q
Offline bill bischoff
Re: repairing the Glowbee Fireplug
« Reply #1 on: December 21, 2012, 03:27:39 PM »
They have a fusible link between the battery and the negative terminal. Check this for continuity with an ohm meter. If it's blown (open circuit), replace it with a piece of wire. This seems to be the most common failure.
« Last Edit: December 21, 2012, 04:10:02 PM by bill bischoff »
Offline BillLee
« Reply #2 on: December 21, 2012, 06:18:40 PM »
What Bill said!
I have also had the contacts in the pot get cruddy to the point that I couldn't get current flow. Took it apart and cleaned all the contacts with some 400 Wet or Dry and all is o.k.
Bill Lee
AMA 20018
