  • June 14, 2025, 05:47:57 PM
Author Topic: RSM STUKA KIT ???  (Read 4473 times)
Offline Vincent Corwell
RSM STUKA KIT ???
« on: September 06, 2006, 02:01:39 AM »
Hi all
anybody got experience of RSM Stuka kit please?
thinking of my TT25 which flies the Flite Streak
so well
Vincent
Re: RSM STUKA KIT ???
« Reply #1 on: September 06, 2006, 06:28:26 AM »
Hi all
so well
Vincent
Eric's Stuka is of high quality, and is a fairly small plane as full stunters go.  The TT25 should be great in it.  Only issue I could see would be the weight of the TT25, but it isn't bad.  I have flown the Stuka on an old Fox 25 (three bolt backplate from '57) and it had plenty enough grunt to do hte job.  A TT25 should be stronger!
Bill <><
Offline dennis lipsett
« Reply #2 on: September 06, 2006, 07:29:41 PM »
Bill, I don't think that there is enough of a weight penalty in the TT25 vs the Fox 25 to get too excited about. I've used that and the OS25 in quite a few planes both small and large and balancing the ship is not a problem, nor managing the power. The TT 25 will fit in that cowl beautifully and probably do a nicer job then the Fox 25. I'm partial to modern motors and while I have the Fox 25 it stays in the box, I never liked a 4/2/4 run.
Dennis
« Reply #3 on: September 07, 2006, 09:58:16 AM »
Dennis
Hi Dennis,
Thanks!  Like I said:
"The TT25 should be great in it.  Only issue I could see would be the weight of the TT25, but it isn't bad."
Do you have the old '57 Fox 25??  If you are not planning on using it, maybe we could mke a deal. :)  I still like a *little* break in my engine run.  Even the PA 61s on pipe are running a "break". :)
Bill <><
« Reply #4 on: September 07, 2006, 07:49:12 PM »
I haven't built one, but I purchased one for a friend and got a chance to check it out. Everything looked very nice, with great wood and quality cutting, nice kit. ;D
« Reply #5 on: September 08, 2006, 10:39:31 PM »
Bob Smiley from Kingston, WA/Tucson, AZ had an RSM Stuka with a .25LA. It was an excellent combination for a smaller person, but not quite right for windy conditions. It would fit nicely in a small car, as long as you use cable leadouts. Randy Powell may have flown it, so you might get an answer from him.   ~^ Steve
Offline Ron King
« Reply #6 on: September 11, 2006, 02:24:37 PM »
I have one under construction. Fabulous kit; great wood. Mine will be powered with an OS LA25. That engine puts out plenty of power.
As mentioned above, it is a much smaller plane than I remember as a teenager.
Enjoy,
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
« Reply #7 on: September 12, 2006, 05:59:09 PM »
Can't wait to see her done Ron! f~
« Reply #8 on: September 20, 2006, 05:09:06 AM »
I am going to buy one of these kits in October, ( waiting for cash!!)
what is an acceptable colour scheme please, non military
post fotos please
and oblige
Vincent
Offline Leester
« Reply #9 on: September 20, 2006, 08:48:32 AM »
If you can swing it earlier you'll save some $$$  Prices go up I believe Oct. 1 on RSM kits.
Leester
ama 830538
« Reply #10 on: September 21, 2006, 09:11:26 PM »
Vincent,
 Here's an idea that would be VERY cool, EASY, and something COMPLETELY different.
 You could do the Stuka in a solid bright red, put WWII era U.S. stars and bars on it, and pretend it's one captured by the U.S. during the big one. The stars and bars can be purchased from Sig on a sheet and are really cheap, or, Major Decal has some too that are a little more $. Most good hobby shops carry both, or can get them for you.
 Man, I've got myself thinking on this one... >:D
Have fun! n~
« Last Edit: September 23, 2006, 02:54:36 PM by wwwarbird »
