  • July 02, 2025, 10:42:09 PM
Author Topic: Twin Streak kits  (Read 6488 times)
Offline pat king
    • PDK LLC
Twin Streak kits
« on: December 15, 2011, 10:43:21 AM »
The Twin Streak laser cut kit is a 53.8 inch wingspan , 535 square inches of wing area, twin airplane. All parts are laser cut. The two fuselages are 12 ½” center to center.  The airplane is for .15 to .20 engines. If you like Streaks and want a twin, this is for you.  y1
Thanks,  Pat
« Last Edit: December 15, 2011, 11:10:04 AM by pat king »
Pat King
Monee, IL
AMA 168941
Offline John Miller
Re: Twin Streak kits
« Reply #1 on: December 15, 2011, 11:20:58 AM »
Hi Pat, You've done a good job on the streak twin. I have some experience with twin flight streaks, and may I offer a suggestion that may be helpful.
You've mounted the bellcrank to the inboard fuselage. You might find that it is better to mount it next to the outer fuselage. This will save you having to have a lot of tip weoght to balance out the weoght of the BC inboard of center. I once did one as shown, and had to use 1 1/2 OZs of tip weight. The next one with the BC mounted near the outboard fuse, only needed 1/2 OZ to balance. y1
Offline pat king
    • PDK LLC
« Reply #2 on: December 15, 2011, 02:35:02 PM »
John,
Thanks for the tip. I will move the bellcrank out before anything goes to be laser cut. y1
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
« Reply #3 on: December 15, 2011, 02:43:24 PM »
John,
Thanks,  Pat
Hi Pat,
First, thanks so much for the phone call.
Second,  do you have a price estimate yet?
Offline pat king
    • PDK LLC
« Reply #4 on: December 17, 2011, 04:50:08 AM »
Bill,
The first ones will be $90.00, I will adjust the price from there.
Thanks,  Pat
P.S. I will catch up with you.
Pat King
Monee, IL
AMA 168941
« Reply #5 on: January 07, 2012, 10:35:20 PM »
Pat, are the twin Streaks available yet? I want one!
Offline pat king
    • PDK LLC
« Reply #6 on: January 08, 2012, 10:17:37 AM »
Clint,
I will order the laser cut parts today.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
« Reply #7 on: January 12, 2012, 05:56:07 PM »
Clint,
Thanks,  Pat
Cool, just let me know what to do and when to do it.
« Reply #8 on: March 29, 2012, 07:31:38 PM »
Got my Twin Streak yesterday. What a cool looking plane! This thing is going to sound so awesome screaming around the circle!
Thanks Pat. 8)
Offline Scott Pahlow
« Reply #9 on: August 10, 2012, 09:05:46 AM »
Pat,
 Do you have any Twin Streaks left? Are they still $90.?
 I would love to build one. Do you think 2 - LA.25 would be to much? I already have them.
 Thanks.
 Scott Pahlow
Offline pat king
    • PDK LLC
« Reply #10 on: August 10, 2012, 03:03:54 PM »
Scott,
I do not have any Twin Streaks in stock. They are now $95.00 with shipping and insurance included. My laser cutter goes on vacation in a week and is covered up until he leaves. It could be 6 weeks until I can get a kit to you. You can pay using PayPal to: patdk at aol dot com or you can send a check to:
Pat King
5133 W. Jason Dr.
Monee, IL 60449
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #11 on: August 10, 2012, 03:06:29 PM »
Scott,
As for Twin Streak engines, the LA25 engines are more than the airplane needs, but it is not hard to back off on the power by using a flatter prop and a richer run. There is no way to compensate for a powerplant or powerplants without enough power.
Pat
Pat King
Monee, IL
AMA 168941
