  • June 14, 2025, 05:25:54 PM
Author Topic: Ringmaster 850  (Read 3404 times)
Offline pat king
    • PDK LLC
Ringmaster 850
« on: August 05, 2013, 07:18:14 AM »
Here is the Ringmaster 850. It is basically a 1 1/2 scale Ringmaster with a thicker, stronger wing. The rib profile is based on an Eppler 479. The wing is 2 3/4" thick at the high point.The wingspan is 63" and the wing area is 853 square inches. The fuselage is two pieces of 1/4 balsa with cutouts to reduce weight. The fuselage is skinned with 1/16 balsa that butts against the 1/8 aircraft ply doublers. The horizontal tailfeathers are 1/4 balsa without cutouts and 1/16 balsa sheeting. The laser cut kits are $182.50 with shipping and insurance included to the lower 48.
Thanks, Pat
Pat King
Monee, IL
AMA 168941
Re: Ringmaster 850
« Reply #1 on: November 08, 2013, 09:40:08 PM »
 That's cool. y1
 Is that a K&B .60 on the one in the photo?
