  • June 14, 2025, 05:29:59 PM
Author Topic: RINGMASTER X-WING  (Read 3334 times)
Offline pat king
    • PDK LLC
RINGMASTER X-WING
« on: October 05, 2013, 06:00:05 PM »
The Ringmaster X-Wing is a 60 size biplane that is not a traditional biplane. The airplane has a 49.65” wingspan and 936 square inches of wing area. It has adjustable leadouts, a weight box, and a cutout through the fuselage for a 5 oz. tank. The airplane has a cowl cheek on the mounted to the inside of the circle. The airplane has a “V” tail. The kits will be laser cut with 3 sheets of CAD plans. The plans show all parts full size. The kits will not have any control system hardware.
Pat King
Monee, IL
AMA 168941
Re: RINGMASTER X-WING
« Reply #1 on: October 07, 2013, 07:15:48 PM »
Pat,, curious,, interesting design,,
have you built one and flown it
does it have any strange habits?
Offline pat king
    • PDK LLC
« Reply #2 on: October 12, 2013, 09:34:40 AM »
Mark,
The airplane hasn't been built yet. The cutting files are not done. There are or have been full size racing biplanes with this wing configuration. There should be no bad flight characteristics. The airplane is not intended to be a precision aerobatic airplane. I am confident it will be good for inside and outside loops, wingovers, inverted flight, and figure eights. I wouldn't expect it to be an airplane for square or triangular maneuvers.
Sorry to be so long getting back to you, I was out of the country.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #3 on: November 05, 2013, 01:26:48 PM »
I'll be ordering the first run of kits on Saturday. The kits will sell for $195.00 post paid in the lower 48 states. I need at least a deposit or a check in the mail by 10:00 PM Friday. You can send a check to:
Pat King
5133 W. Jason Dr.
Monee, IL 60449
or PayPal to patdk at aol dot com
Thanks, Pat
Pat King
Monee, IL
AMA 168941
