  • June 14, 2025, 04:18:38 AM
Author Topic: Martin AM-1 Mauler Profile Scale  (Read 3503 times)
Offline pat king
    • PDK LLC
« on: November 05, 2016, 11:30:54 AM »
A Profile Scale laser cut kit of the Martin AM-1 Mauler. The airplane is 1” = 1’ scale.  The airplane has a 50” wingspan and 480 square inches of wing area. The airplane is designed for .40 to .45 engines, the original was powered by an R4360, do not underpower this airplane. The plans are CAD plans and have full size templates of all the parts. The kit contains all the laser cut parts, the sheet and strip wood, the maple for engine mounts and gear mounts. The kit contains the wire for the landing gear. The kit will include a .pdf of the 1948 Model Airplane News drawing emailed to the purchaser. The kit does not contain any control system hardware. The kits will sell for $160.00 plus shipping. Figure shipping at 5 pounds shipped Priority Mail from 60449. If you want the shipment insured for more than the $50.00 included in the Priority mail postage include the extra and indicate the dollar figure for insurance. A set of full size .pdf files of the plans and an 8 ½ X 11 .pdf of the 1948 Model Airplane news drawing are available for $6.00 .
« Last Edit: November 06, 2016, 10:53:55 AM by pat king »
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: Martin AM-1 Mauler Profile Scale
« Reply #1 on: November 05, 2016, 09:20:53 PM »
Ty is correct, the Mauler is the same size as the Skyraider. The Mauler came with an R4360 up front where the Skyraider came with an R3350. The Mauler had a very short service life.
Pat
Pat King
Monee, IL
AMA 168941
Offline skyshark58
  • skyshark58
« Reply #2 on: November 06, 2016, 12:51:01 AM »
Pat,
 You need to revisit your horizontal stab and elevator design, it is not "scale".
  Both elevators have a counter balance on their outboard ends that extends forward to the leading edge of the horz stab. Also the section next to the inboard end of the elevators is fixed and part of the fuselage.The Three view drawing shows these details.
  If you could reduce the size to about 340 sq inches of wing you would have a Profile Class Navy Carrier event kit !
        Mike Potter
mike potter
Offline pat king
    • PDK LLC
« Reply #3 on: November 06, 2016, 10:59:54 AM »
Thanks Mike.
Mike is correct, I missed the extended horizontal stabilizer when I returned to this one. I finally found a picture that shows that the elevators are aerodynamically boosted. The design has been fixed.
A 340 square inch profile carrier version would have a 42" wingspan if the aspect ratio is not changed. I fear that the market for a profile carrier airplane would be less than the market for the profile scale version.
Pat King
Monee, IL
AMA 168941
Offline skyshark58
  • skyshark58
« Reply #4 on: November 06, 2016, 03:39:11 PM »
Pat,
  Looks correct now! A smaller version would still be ok for scale and would also work for carrier. Hit both markets,small as they both are.  Mike
mike potter
