  • July 11, 2025, 05:41:53 PM
Author Topic: What to use for primer  (Read 1260 times)
Offline James Mills
« on: February 17, 2011, 07:06:10 PM »
I've used Polar Gray (both SIG and Brodak) in the past with a little white mixed in for the primer coats and was wondering what else I could use (doing a dope finish) that I can get at the local paint supply and not have to mail order?
James
AMA 491167
Re: What to use for primer
« Reply #1 on: February 18, 2011, 11:36:34 AM »
James,
Well, I usually make my own filler/primer coat. Some white, a touch of black (to make gray) and filler (either zinc sterate or talc) and clear dope. Then a blocking coat - the color of the block coat depends on what I using for a base color. Sometimes silver, sometimes gray, sometimes gold. It depends.
« Reply #2 on: February 27, 2011, 11:56:24 PM »
I use a ready made commerically avaliable white acylic  based primer ..
« Reply #3 on: February 28, 2011, 02:18:57 AM »
Hi James,
Are you talking "primer/filler" or "blocking coat"?  I have used Duplicolor spray can lacquer gray filler/primer all the time under dope.  Sparky uses primer in spray cans from NAPA (gets it by the case).  I have used several different PPG and DuPont automotive primers under dope and all have worked well.  Quarts or gallons of DuPont "Fill 'n' Sand", but I don't have the part number right now.  It works really well.
If its for a "blocking coat", then I use automotive lacquer or dope.
Big Bear
