  • July 31, 2025, 06:48:37 PM
Author Topic: .what method  (Read 3525 times)
Offline Bootlegger
.what method
« on: February 19, 2009, 10:30:00 AM »
     y1    Mornin guy's, What method do ya'll use to make a pattern of your engine's lug mounting? What I'm trying to do is set up a holder that will bolt in where the engine goes to mount in a spray stand for painting my model.
 Any help sure will be 'ppreciated...... #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: .what method
« Reply #1 on: February 19, 2009, 10:51:04 AM »
Hmm, well, I cut a plate to the correct size to fit the engine mounts and just sort of do eyeball measurements. I drill the holes out big enough to allow for some error.
The other option is to find someone with a CAD drawing of the engine including top view and just use that as a pattern.
  • Gravitywell
Re: .what method
« Reply #2 on: February 19, 2009, 11:12:59 AM »
I do it with three strips of poster board (or file folder stock) that are about one inch wide, by whatever length you need.  I use post-it note glue and glue one under each lug....then use regular glue to glue one across the back that fits against the back of the case.  Then mark the holes, remove the entire thing in one peiceand voila.....you have your perfect template.  I hope this makes sense, I haven't had my morning gup of coffee yet!  D>K H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Bootlegger
Re: .what method
« Reply #3 on: February 20, 2009, 07:56:36 AM »
     Thanks guy's, Gravitywell I like that idea..  Again thanks guy's..  Sparky, thanks for this forum.    #^     :!
Gil Causey
AMA# 6964
