  • June 15, 2025, 03:37:09 AM
Author Topic: Decisions,decisions.....  (Read 1876 times)
Offline jim gilmore
« on: March 11, 2009, 02:45:42 AM »
'm getting close to where I needto decide how I'm going to finish the shaark 402. First off, I know where there is an ace hardware that I pass ofen enough in my travels. I'm considering painting the fuselage and tail and monokote the wing. What I  need to know is do I use some thing to fill the wood grain before use the ace hardware paint? Can I paint the fuselage and tail, the glue the wing in after or do I need to glue the wing in first ?
Most likely Black fuse and red  wing and horizontals. Maybe some yellow trim.
Re: Decisions,decisions.....
« Reply #1 on: March 11, 2009, 07:33:15 PM »
you dont have to fill the wood with something, but it sure does look alot better if you do. When I do the type of finish you're doing, I dope the wood with a couple coats of nitrate dope, then apply silkspan, the a couple more coats of dope lightly sanded between coats. With all the parts covered, I now assemble the plane then use rattle can primer, sand, then color. if you're going to put fillets in, do it before you start the primer.
