  • June 14, 2025, 11:06:06 PM
Author Topic: dope question  (Read 3078 times)
Offline Russell Shaffer
dope question
« on: December 07, 2015, 01:34:10 PM »
I'm low on tautening dope.  Can I fill the weave with non tautening and then switch to tautening and get decent results?  Keep in mind that for me, "finish" means that it's done.  Thanks
Russell Shaffer
Klamath Falls, Oregon
Re: dope question
« Reply #1 on: December 07, 2015, 01:54:28 PM »
I would say a definate maybe,,
you MIGHT be able to cheat this by overreducing the clear dope, but it will take LOTS more coats ( wont leave more on the plane, )
by over reducing it you cause it to shrink out more, so you might get some tautening effect,,
best not use that nylon like the ringmaster,, just sayin
Offline billbyles
Re: dope question
« Reply #2 on: December 07, 2015, 02:31:37 PM »
Russell,
Probably won't work well.  The tautening dope relies on penetrating the covering material so it will have a pliable coating to shrink with the dope.  Best to start with the tautening dope.  If you don't have enough tautening type then if the covering is pretty smooth as applied you may get away with using the non-tautening dope as it shrinks about 4% to 5%.  Tautening shrinks around 10% to 12% and shrinks sooner.
Bill Byles
AMA 20913
So. Cal.
Re: dope question
« Reply #3 on: December 07, 2015, 02:51:55 PM »
Thanks.  I'll use tautening until it's done or I run out, then switch.  Mark, that nylon went away, never to be used again for airplanes. The Ringmaster is also gone, salvaged for parts.
Russell Shaffer
Re: dope question
« Reply #4 on: December 07, 2015, 02:55:26 PM »
Russell, did it finally die, or did you commit mercy killing,,
that was the scariest thing to fly,, lol not to mention looking at it was frightening, or maybe it was just the looking at it LOL
and people wondered why you were so willing to let anyone,, and I mean ANYONE fly it LOL
go get some more taughtening dope man,, you know what its like to fly with loose covering,,  LL~
Re: dope question
« Reply #5 on: December 07, 2015, 03:37:43 PM »
Bill planted it in the grass in Salem but it was fixable with minor effort.  I did think about fixing it but it was such of piece of fine workmanship that I decided to let it die peacefully.
Russell Shaffer
Re: dope question
« Reply #6 on: December 07, 2015, 04:05:22 PM »
egads.,
so what does that leave me to tease you about now?
I guess the rubber banded wing thing, but its so weird its cool, so I cant harass you about that one,, hmmm
I guess I will just have to be quietly supportive now ,,
so much for my fun,,,,, HB~> LL~
Offline billbyles
Re: dope question
« Reply #7 on: December 07, 2015, 04:28:30 PM »
Hi Russell,
I should have mentioned this in my first post: I do just the open bays with the tautening dope for the first 3 coats or so, & the rest of the airplane with the non-tautening dope.  That way it takes very little tautening type dope.  Tautening & non-tautening type dopes are completely compatible with each other (no doubt you already knew that but thought I'd throw it in.)
Bill Byles
AMA 20913
So. Cal.
Re: dope question
« Reply #8 on: December 07, 2015, 05:06:45 PM »
Thanks Bill.  I think I actually have enough on hand now.  I'll follow your advice.
Russell Shaffer
Re: dope question
« Reply #9 on: December 07, 2015, 05:40:43 PM »
Russell, the NWSR banquet is sometime in January...I might be able to arrange for a gallon of clear Randolph to attend the banquet, if you plan to attend again.  ;)  Steve
Re: dope question
« Reply #10 on: December 08, 2015, 10:13:56 AM »
A gallon would probably last longer than I will.  I doubt I'll see you this January.
Russell Shaffer
Offline Fredvon4
  • Central Texas
Re: dope question
« Reply #11 on: December 08, 2015, 12:04:55 PM »
Hey Steve. if I fly up can I get a gallon also?   **) S?P
Grin
I need to make a road trip to my daughter in Dallas (closest aircraft supply is up her way 3 hrs trip from me) and get a gallon of good dope...got too many builds to suffer the expense of more Sig dope although I like the stuff
Fred von Gortler IV
