  • July 31, 2025, 05:39:16 AM
Author Topic: Never had this happen before  (Read 6053 times)
Offline Mike Griffin
« on: December 30, 2023, 01:20:30 PM »
I have been covering with polyspan for years and never had his happen.  I made sure the slick/shiney side was up when I covered the wing.  I filled it with dope and filled it as always.  Did not have any fuzzies at all.  When I have the covering filled adequately with dope, I put it on the paint stand and sprayed on a light coat of Klass Kote white and had fuzzies appearing everywhere.  I think my only solution at this point is when the paint is dry, to wet sand with a fine grit paper.  I have never had to do this so my question is what grit should I use to wet sand, 1000, 1500, 2000???
« Last Edit: December 31, 2023, 10:02:36 AM by Mike Griffin »
Offline Larry Renger
Re: The fuzzies
« Reply #1 on: December 30, 2023, 03:32:55 PM »
2000 grit wet sanded should do it for you. 🤠
Re: The fuzzies
« Reply #2 on: December 30, 2023, 05:06:15 PM »
Thank you Larry. I just never had to deal with this before and have no idea what caused it.
