  • June 15, 2025, 12:37:11 AM
Author Topic: Decals  (Read 12123 times)
Offline John Skukalek
Decals
« on: September 28, 2023, 04:00:20 PM »
Does anyone know if water slide decals put on monokote then coated with Z-Poxy finishing resin would work?
Re: Decals
« Reply #1 on: September 28, 2023, 04:13:51 PM »
I can't comment on Z-Poxy but I have used them with Rustoleum clear over Monokote.  FYI - I am electric.
« Last Edit: October 18, 2023, 09:48:01 PM by Ken Culbertson »
Offline bill bischoff
Re: Decals
« Reply #2 on: September 28, 2023, 07:14:07 PM »
I was just using Z-Poxy finishing resin this evening. If nothing else, it is not very clear.  :'(
Offline John Paris
Re: Decals
« Reply #3 on: October 18, 2023, 06:23:41 PM »
John,
I have had decent luck using Krylon Cover Maxx clear over the decals while still on the paper.  Normally a couple of coats does the job.  No issues with the decal sliding off the paper and onto the airplane and the decal is pretty fuel and cleaner resistant thus far.
Rustoleum clear is not fuel proof as I understand it while their colors are.
Good luck.
John Paris
269
Offline fred cesquim
    • Fred Cesquim Aeromodelos
Re: Decals
« Reply #4 on: October 19, 2023, 04:20:47 AM »
will become brown and look pretty ugly in no time
use clear coat and will be great, i clear coat all of my monokote coverings with no issues
the PAMPA logo on this picture is water slide, remaining colors are painted over red translucent monokote
Offline kevin king
Re: Decals
« Reply #5 on: January 02, 2024, 02:54:02 PM »
Fred, what type of clear coat are you using over the decals? 2k ?
Offline Steve Dwyer
Re: Decals
« Reply #6 on: January 03, 2024, 06:18:43 AM »
Good luck.
John,
Just to clarify Rustoleum colors is not fuel proof, but it is fuel resistive. The "Stops Rust" seems to stand up better than their "2X". You must always wipe raw fuel off to be safe. I have no experience with their clear, I'm sure it follows suit. Once the Rustoleum has cured you can spray a two part auto clear coat or KBS Diamond single stage over the finish including the slide off or vinyl decals. Watch your added weight! I have no experience with Krylon finishes.
Offline John Paris
Re: Decals
« Reply #7 on: January 03, 2024, 06:51:59 PM »
Steve,
Thank you for the insight.  I have only painted one with Rustoleum so do not have much experience.  Seems that Allen Brickhaus was a fan of it (or perhaps another canned spray) to get things in the air quickly.  Do not know if he clear coated after the color or not though.
John Paris
269
Re: Decals
« Reply #8 on: January 03, 2024, 07:00:32 PM »
Steve,
I have had no issue with Rustoleum clear over monokote to protect decals.  I have heard that it is a different formula from the colors and not as fuel proof.
Re: Decals
« Reply #9 on: January 05, 2024, 03:52:07 AM »
yep, 2k auto clear, over paint, decals and monokote.
Re: Decals
« Reply #10 on: January 05, 2024, 12:46:18 PM »
Fred,
For going over the MonoKote did you need to use any adhesion improver for plastic?
Best,   DennisT
