  • June 17, 2025, 10:19:35 PM
Author Topic: Paint mask?  (Read 943 times)
Paint mask?
« on: March 25, 2013, 05:14:13 PM »
Would it be advisable to leave paint mask on for a few days.
Reason I am asking is i would like to have my plane all masked off and ready to paint when the wind, rain and snow is gone.
Thanks in advance!
Offline Gene O'Keefe
Re: Paint mask?
« Reply #1 on: March 25, 2013, 06:07:12 PM »
Depends alot on the "adhesion" of the tape you are using. Some are a real chore to get off after they set in and
"dry" so to speak. If you are using "low" adhesion, I would think no longer than 2-3 days. JMHO.
Gene O'Keefe
AMA 28386
Re: Paint mask?
« Reply #2 on: March 25, 2013, 06:58:12 PM »
Thanks in advance!
Paul,
If you're using professional grade mask material, like the mask material I provide, it doesn't matter. I would just make sure all the edges are laying down properly before I did the shoot or the brushwork.
Yes, there's no set rule that says masks have to be sprayed. I've brushed paint in masks before, especially with thin lettering.
 Charles
