  • July 12, 2025, 02:07:04 AM
Author Topic: Starting primer coats  (Read 974 times)
Offline James Mills
« on: March 07, 2010, 06:52:50 PM »
I finally shot the first coat of primer on my Formula S today (brodak polar gray w/a little white mixed in).  As usual with primer, it's Coyote ugly.  I went through the polyspan when sanding the fillets neat the wing, what's the best fix at this point (CA, tissue, thin coat of epoxy)?
James
AMA 491167
Re: Starting primer coats
« Reply #1 on: March 07, 2010, 10:16:17 PM »
James,
I'd probably go with CA.
