  • May 24, 2024, 12:05:16 AM
Author Topic: Humidity level.  (Read 1713 times)
Offline Perry Rose
Humidity level.
« on: July 02, 2017, 08:59:04 AM »
What percent humidity "should" produce a blush free clear coat? I'm using Rustoleum 2X clear. Or, for the pro's, what humidity level do you require before you paint? I put a de-humidifier in the room set at 45%.
Re: Humidity level.
« Reply #1 on: July 02, 2017, 09:04:38 AM »
  • I don't know the answer
  • It's gonna depend on the paint chemistry, and if you're not using spray-bombs, whether you dry the air coming out of your compressor
  • I thought it was only an issue with dope or other laquer-based paints -- what's this Rustoleum stuff?
Offline Perry Rose
Re: Humidity level.
« Reply #2 on: July 02, 2017, 09:28:36 AM »
Rustoleum spelled sideways is "better than dope".
Offline billbyles
Re: Humidity level.
« Reply #3 on: July 02, 2017, 10:49:11 AM »
Hi Perry,
Rustoleum is fine at 45% humidity, and it is much less sensitive to humidity level than is a fast evaporating material such as dope.
Bill Byles
AMA 20913
So. Cal.
Offline Perry Rose
Re: Humidity level.
« Reply #4 on: July 02, 2017, 11:08:53 AM »
After the dehumidifier runs for a few days I'll give it a try.  Thanks.
Re: Humidity level.
« Reply #5 on: July 02, 2017, 03:53:17 PM »
Don't forget to factor in the temperature as I have had problems with low humidity and high temps.
Re: Humidity level.
« Reply #6 on: July 02, 2017, 08:27:33 PM »
Randolph says 50% max if you care about blush.
I like to go to Colorado in the summer for best results.
Offline billbyles
Re: Humidity level.
« Reply #7 on: July 03, 2017, 04:23:16 PM »
<snip>
Randolph makes enamel, dope, and polyurethane paints.  Each product has its own sensitivity to humidity with dope being the most sensitive to humidity, enamels next less sensitive, and 2-part polyurethanes being the least sensitive.  I spray dope in a temperature range of about 65 to 95 degrees F, and in a humidity range of about 65 to maybe 70% maximum.  I will spray in low humidity such as 10% RH and temperature in the range shown above and add butyrate retarder as needed.  This is for full-scale airplanes as well as models.  You just have to try spraying & adjust the mix & technique as you go.
Enamels can be adjusted somewhat by varying the speed of the reducer, and for acrylic enamels a hardener is available that improves the gloss & chemical resistance appreciably.  Two-part polyurethanes are the easiest to work with in widely varying temperature/humidity conditions; various speed reducers are available along with various speed catalysts as well as accelerators to accelerate the cure time.
Rustoleum (spray cans) is an excellent product but there is not anything you can do to vary the paint mix.  You just have to pick your conditions and you can end up with excellent results.
Bill Byles
AMA 20913
So. Cal.
Offline Jim Svitko
Re: Humidity level.
« Reply #8 on: July 03, 2017, 09:13:10 PM »
We tend to focus on the humidity reading but ignore the dew point.  While watching the weather reports here in DFW for the past few weeks, the relative humidity some days was around 50%, temperatures of 90 F or above, but the dew point was around 72 degrees.  Maybe these conditions are OK for finishing systems other than dope but with a dew point that high I would never attempt spraying dope.
Offline billbyles
Re: Humidity level.
« Reply #9 on: July 04, 2017, 11:44:29 AM »
Hi Jim, I agree about the dewpoint factor.  I overlooked it because here in So Cal it is very rarely a factor.  Good point.
Bill Byles
AMA 20913
So. Cal.
Offline Allan Perret
  • Proverbs
Re: Humidity level.
« Reply #10 on: July 21, 2017, 10:59:13 AM »
I thought for a given temp there was a direct correlation between humidity and dewpoint ?
You saying at 50% humidity,  18° is not enough spread between dewpoint and actual temp ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: Humidity level.
« Reply #11 on: July 21, 2017, 11:54:28 AM »
Perry,
I've never paid any attention to it. I said many times I paint and clear all my models outside paying absolutely no attention to weather conditions except for rain.
I've applied the clear I use on really damp days and on days with great sunshine without ever having an issue with blushing. One day I had just made it before it started to rain.
I don't use dope or Rust-o-leum.
The only blushing I experience is with myself when I get kudos for the finish on my models.  LL~
Here's one example. ;D
CB
Offline Jim Svitko
Re: Humidity level.
« Reply #12 on: July 21, 2017, 01:42:50 PM »
I would have thought 18 degree spread would be enough but sometimes it is not.  I have sprayed dope under the conditions stated but I needed more retarder than what I prefer to use.  Even with retarder, there was some blush.  So, I prefer to wait for better conditions.
A few weeks ago I was doing some touch up in the house, brushing on some dope, and getting blushing.  We had such muggy conditions even the Sigment was blushing.
