  • July 16, 2025, 04:34:57 AM
Author Topic: SLC??  (Read 1577 times)
SLC??
« on: July 18, 2012, 10:39:57 AM »
HI All,
Looking for some wisdom about using SLC.  We covered Aaron's Trophy Trainer with it but the wing tips really suck! LOL!!  Is there any secret to doing wing tips correctly?
I have used it on the open bays only with a big stunter but covered over it with silkspan which covered the wingtips.
HELP!!!!! ;D
Re: SLC??
« Reply #1 on: July 19, 2012, 11:08:43 AM »
Use a separate peice for the wing tips.  Or as most say, go the silkspan route.  Myself I turn up the iron while doing the  tips  and do some pulling.  Still get wrinkles, but I am not going for 20 point finish with it either. H^^
Offline MarcusCordeiro
Re: SLC??
« Reply #2 on: August 08, 2012, 03:18:23 PM »
Yeah, the wingtips suck...
I've tried cutting with scissors where the wrinkles form before ironing.
That's what has worked the best for me.
I also use a separated part for the tips.
On this P51 I got no wrinkles..(luck!?)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: SLC??
« Reply #3 on: August 08, 2012, 04:21:55 PM »
Thanks, Doc and Marcus!
Offline Bootlegger
Re: SLC??
« Reply #4 on: August 09, 2012, 04:52:39 AM »
  Coach, first how are ya' doing with the treatments? Gotta get well and strt flyin again ole pal.
Second question, how does SLC work on a foam wing that is partially covered with balsa?  (l/e t/e center section) how hot do you have to set the iron?
                    Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline bob branch
Re: SLC??
« Reply #5 on: August 10, 2012, 08:08:29 AM »
SLC works pretty similarly to ultracote. Has much more shrink capability than monocote, but not as much as ultracote. There is a section on the T-Rex build thread I did on the electric forum that shows in detail how to do wingtips in film.
bob branch
