  • July 13, 2025, 01:46:56 PM
Author Topic: Silkspan over pants?  (Read 1309 times)
« on: May 10, 2011, 05:58:16 PM »
So first time with wheel pants. Do you put silk span on them as well?
Re: Silkspan over pants?
« Reply #1 on: May 10, 2011, 06:06:08 PM »
Whatever your chosen method of filling the wood grain is, do it everywhere.  If you're filling grain with silkspan -- put silkspan on the pants.
« Reply #2 on: May 10, 2011, 06:39:19 PM »
You relative novices need some advice from a guy who's been there.  If you put silkspan on your pants, take them off before applying dope, particularly thin dope which could run into the inside.  Similarly, take them off before ironing on MonoKote, particularly on the crotch area.
Hope this helps.
Offline Dan Bregar
  • Field Marshall
« Reply #3 on: May 10, 2011, 07:02:42 PM »
Not to contradict my friend Howard, but you may want to apply .50 oz glass cloth to toughen them up a little to better handle the wear & tear they may get.  And most certainly take uncle Howard's' astute recommendations, by all means.  ;)
AMA 33676
« Reply #4 on: May 10, 2011, 07:12:11 PM »
So maybe use fiberglass and z-poxy?
Offline Dan Bregar
  • Field Marshall
« Reply #5 on: May 10, 2011, 07:25:45 PM »
Yeah, the finishing resin.  Thin it out ( I use denatured alcohol) and brush it on, and blot the excess with toilette tissue or a paper towel to limit the weight build up.  :)
AMA 33676
Offline Mike Haverly
« Reply #6 on: May 11, 2011, 04:42:34 PM »
Nothing wrong with polyspan, been there done it!  Do half at a time with the seam running for and aft.  Not as hard as you think, give it a try.  ;)
« Reply #7 on: May 11, 2011, 05:01:09 PM »
I generally use silkspan mostly because that's weight a long way from the vertical CG. The lighter the gear (and wheelpants) are, the better.
« Reply #8 on: May 11, 2011, 09:38:28 PM »
I tried glass, but it's itchy.
« Reply #9 on: May 11, 2011, 09:57:21 PM »
How about carbon, Howard? Seems you use a lot of that.
« Reply #10 on: May 12, 2011, 09:28:08 AM »
Silkspan, Silk, or 1/2 oz. fiberglass cloth applied with Zap Z-poxy.  I like the FG best of all, much more durable.
Big Bear
« Reply #11 on: May 12, 2011, 09:38:42 AM »
Hope Howard keeps his day job.   LL~ LL~ LL~ LL~ LL~
