  • June 16, 2025, 07:59:06 AM
Author Topic: Brodak color on top of Randolph clear  (Read 1534 times)
Online Paul Taylor
« on: May 16, 2011, 01:32:30 PM »
Has any every put Brodak colors over randolph clear butyrate?
Then put randolph clear back over top of Brodak colors?
Offline Mike Haverly
Re: Brodak color on top of Randolph clear
« Reply #1 on: May 16, 2011, 03:23:23 PM »
Yep, no problem just allow proper dry times.
Offline Allan Perret
  • Proverbs
« Reply #2 on: May 16, 2011, 03:36:52 PM »
I have done exactly that with the current finish I am working on.    But I did use the same thinner for both.   No Problem...
Allan Perret
AMA 302406
Slidell, Louisiana
Online Paul Taylor
« Reply #3 on: May 16, 2011, 07:02:38 PM »
Thanks guys.
Hey Allen, was that Brodak thinner or Randolph thinner?
« Reply #4 on: May 16, 2011, 10:31:49 PM »
I've done exactly what you describe with Randolph thinner throughout. No problems at all. I would expect the same result with Brodak thinner.
  • Proverbs
« Reply #5 on: May 17, 2011, 06:45:54 AM »
Thanks guys.
Neither, I used Finish Pro Slow lacquer thinner which I can get in gallons ($24) at my local auto body supply shop.
I also added about 10% Randolph retarder, but only for the final clear coats.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Robert Schroeder
« Reply #6 on: May 20, 2011, 10:14:37 AM »
Hi Paul,
Check Randolph's web page for distributors.  You'll see that Brodak is a distributor for Randolph's  It is the same dope, however Brodak has made more colors than can be obtained from Randolph, in fact, quite a few and has made it all available in smaller quantities.  Randolph's smallest quantity is a quart.
Ya pays yer money and makes yer choices!
Not a problem with either "Brand".
Bob
Bob from NWO:  If it ain't broke, fix it till it is!
AMA 15083
Offline David Shad
« Reply #7 on: May 24, 2011, 07:32:54 AM »
I get Randolph's dope from Aircraft Spruce and Specialty...it's in South Atlanta about 40 minutes from
me...sure beats paying the shipping.  A gallon of clear is like 47 bucks with colors a little more...thinner
is 24 a gallon for either butyrate or nitrate.  Dopes are available in tautening and non-tautening.
Big Dave AMA 80235
