  • August 05, 2025, 01:31:31 AM
Author Topic: Sig Magnum  (Read 15863 times)
Re: Sig Magnum
« Reply #50 on: April 04, 2013, 09:41:04 AM »
Thank you Charles
What I meant is that sometimes one can't do as much as it was planned.
I'm building 2 ships only... LL~
Work has been killing me, but it's never say die, right?
Today I'm going to have some free time and try to advance a little more both ships.
Marcus
Marcus,
What about that combat model you were excited about? Have you put that asside or did you finish it?
Charles
Offline MarcusCordeiro
Re: Sig Magnum
« Reply #51 on: April 04, 2013, 11:30:17 AM »
It's OK. It needs a little work to be 100%, but it flies great!!
I've got to decrease de venturi dia. 'cause it's slurping fuel and I can't get enough flight time.
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: Sig Magnum
« Reply #52 on: April 04, 2013, 03:31:18 PM »
The canopy...
This is new to me, always been a profile guy...
Gotta find a nice pilot!!
Marcus
Aces High!
Re: Sig Magnum
« Reply #53 on: April 05, 2013, 07:04:37 PM »
The engine cowl... tried to make it the most cooling-efficient I could, not letting the hot air into he tank compartment.
Still have to add the nuts and bolts for fixation.
A few more details and it's gonna be ready for dope and sanding.
i can feel my arms hurt already... LL~ LL~
Marcus
Aces High!
Offline Rafael Gonzalez
Re: Sig Magnum
« Reply #54 on: April 05, 2013, 07:21:57 PM »
Marcus
Try to make the venturi  a little longer. On some engines, the velocity of the incoming air bounces off when  the crankshaft closes and lets fuel and air "backdraft". If you elongate the path, the momentum doesn't come back, it actually pressurizes the inlet at the crank when it opens again. Don't do smaller dia.!!!
 H^^
Re: Sig Magnum
« Reply #55 on: April 05, 2013, 08:07:58 PM »
 H^^
Thanks Rafael.
Marcus
Aces High!
Re: Sig Magnum
« Reply #56 on: April 07, 2013, 05:37:43 PM »
A few adjustments in the engine cowl and that's it.
The pics requested...
Marcus
Aces High!
Re: Sig Magnum
« Reply #57 on: April 07, 2013, 05:53:58 PM »
Marcus,
WOW! That is shaping up!!
Can't wait for the finish. Colors?
Charles
Re: Sig Magnum
« Reply #58 on: April 07, 2013, 11:16:33 PM »
 Thanks for the full pics Marco, looking good. y1
 It's nice to see the whole airplane here to get a "feel". I'm looking for inspiration and ideas for whenever I decide to start mine, which will be modified. VD~
Re: Sig Magnum
« Reply #59 on: April 08, 2013, 05:55:17 PM »
Looking great, Marcus, and should be a great flying model.  Never seen a Magnum that didn't fly well.
BIG Bear
RNMM/AMM
  • Gravitywell
Re: Sig Magnum
« Reply #60 on: April 08, 2013, 06:56:38 PM »
Congrats on your build Marcus.  I have always loved that plane.  Try going through your local Dollar store in the toy department.  I find all sorts of little scale-like figures to put in the cockpit. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Re: Sig Magnum
« Reply #61 on: April 09, 2013, 11:18:47 AM »
Guys
Thanks a lot.
With so many set backs that life, work, family, dogs, etc, make us go thru, building a nice ship, whatever it is, requires a lot of hard work and pacience.
I take a look at it and yhink "Spray the clear and go fly..."
But I, for once in my building career, would like to finish a model properly.
I'm going to have some  free time today, so will try to advance whatever it is that is missing, so I can shoot the first coat of dope....
Having your support, and I mean everybody who check this thread, is really motivating.
Colors will be white, blue and red, to match the "Magnum" sticker that came with the kit.
Just don't know how they will go.
maybe I should bother Marlus a little...
He owes me... Don't you Marlus??? LL~ LL~ LL~
Marcus
Aces High!
Offline Marlus Lago
Re: Sig Magnum
« Reply #62 on: April 09, 2013, 02:36:12 PM »
 Yeah man, just bring it on pal!!!!! ~>
Re: Sig Magnum
« Reply #63 on: April 09, 2013, 07:42:45 PM »
Marcus,
Looking really good. Really looking good!
I noticed you "V"d your stab also. A bunch of extra deflection from that.
Covering material?
Charles
Re: Sig Magnum
« Reply #64 on: April 09, 2013, 09:15:22 PM »
 I just gotta ask, why did you put the tip weight box on the top of the wing?
Re: Sig Magnum
« Reply #65 on: April 10, 2013, 04:19:41 AM »
Wayne, Charles has asked the same question.
No special reason, just thought about doing it differently to see how it'd look.
So, got any ideas for yours?
Are you going to scratchbuild or is it a kit?
I think this ship has elegant lines. I might still have the FM with the report of the releasing of the kit by Sig.
They could offer iy again, don't you think?
Marcus
Aces High!
Re: Sig Magnum
« Reply #66 on: April 22, 2013, 09:26:57 AM »
Borrowed my friend's incidence meter and decided to check the Magnum...
The first pic the screen kept switching 00.0 / 00.1... One has got to have a "light hand" to zero it properly LL~ LL~
Checked wrap too, nothing to report, as the difference was 00.1 from one wing to another. Guess that's OK
One note is that the meter is set for my friend's use, so he does it with the model upside down, therefore when you see the negative, it's actually positive n~
Not bad for some old-school eyeballing barnyard engineering.... D>K H^^
I've taken a break until I get my super fil for the fillets, thought I might improve the way I've been doing it and all the pros are for it...
I'll be doing some sanding meanwhile...
Marcus
Aces High!
Re: Sig Magnum
« Reply #67 on: April 23, 2013, 04:40:14 PM »
Marcus,
Here's the thing.
Place that gadget in many places along the LE/TE. See if it's consistant.  n~
Charles
Re: Sig Magnum
« Reply #68 on: April 23, 2013, 05:14:42 PM »
Charles
I have, and was very happy to see it's OK... Not to mention a little surprised.. LL~ LL~ LL~ LL~ LL~ LL~
Marcus
Aces High!
Re: Sig Magnum
« Reply #69 on: May 08, 2013, 06:17:49 AM »
I've done some serious sanding, and am ready to put on the dope coats.
I'll follow Robert's lead until primer is on.
About the colors, my friend Marlus has convinced me to go like the pic on the box, and he will be helping me out with painting/clear..
I didn't take pics 'cause it's only sanding, but it's getting very good.
Marcus
Aces High!
Re: Sig Magnum
« Reply #70 on: May 08, 2013, 06:35:49 AM »
Marcus,
No photos!
Are you slacking?  n~
Hey! Got a photo of the model pictured on the box?  :o
Can't wait to see the model completed.   H^^
Charles
Offline RC Storick
Re: Sig Magnum
« Reply #71 on: May 08, 2013, 11:26:13 AM »
If you have good eyesight your eye balling of parts with pratice is incredibly close. I can see a few thousands if I look and study. The finish is ALL in the sanding. Good eyes help here as well. Use the light method.
Offline RC Storick
Re: Sig Magnum
« Reply #72 on: May 08, 2013, 11:36:46 AM »
Marcus
If you use a women's emery board on these areas to make them flat and round. Next thing is on your next airplane the wing tip weight box access door goes on the bottom. I am not criticizing what so ever. I was studying your plane and I hope its a optical illusion but which wing is longer? Inboard or outboard?
Use the nail file in the flat and long postion. file one way around the edge and then the other. In a X pattern.
Re: Sig Magnum
« Reply #73 on: May 08, 2013, 02:50:27 PM »
Hey, Marcus, it's looking real good!  The Magnum is always a good flying model.  Don't go too far overboard on the finish, don't let the weight get too high.
I am repairing our Magnum and hope to have it flyable by the time I can fly again.  I originally powered it with a Tower .46, then a ST G.51.  Might use a Randy Smith set up OS .45FSR this time.
Good Luck!
BIG Bear
RNMM/AMM
Re: Sig Magnum
« Reply #74 on: May 08, 2013, 03:07:00 PM »
Thanks Bill and Robert
I'm really willing to have a great finish non this ship.
Robert, according to the plans, both panels are the same, there's no shorter panel.
i've done some sanding on the áreas you pointed out and they look much better now, and the more I sand, the better it gets.
Now, need to buy some 320 grit sand paper and dope is on... Then, guess what, more sanding...
But FWIW, I had this friend who used to own a paint shop, and he was specialized in hi-end models, like mercedes benz and bmw's?
He Always said exactly what Robert says, finishing is sanding, the paint will only show what's underneath with colors...
Robert, I'm not really sure of the emery board you're talking about. Could you post a pic, so I can be sure?
Thanks again people
Marcus
Aces High!
Re: Sig Magnum
« Reply #75 on: May 08, 2013, 03:26:42 PM »
Ok, some pics...
Guys, don't be shy...
Just for fun, measured the wings and everything again, who am I to question Robert's eyeballing?? LL~
Wow, everything is fine...
I wish you guys could feel the wood, so smooth...
Let's continue with the one step at a time for it's been working great.
Oh, a question, should I do the superfil fillets before doping?? If so, will have to wait until I get it...
Marcus
Aces High!
Re: Sig Magnum
« Reply #76 on: May 08, 2013, 03:38:56 PM »
Hi Marcus,
I like to apply the fillets after I have applied what ever covering I use, CF veil or silkspan, etc,.
BIG Bear
RNMM/AMM
Re: Sig Magnum
« Reply #77 on: May 08, 2013, 04:06:20 PM »
Marcus
Robert is precisly correct, as is your friend,, However, just like practicing flying,, simply sanding (or practicing flying) does not insure success,, more QUALITY sanding ( or flying) makes the difference,,
so sand with a plan,, direction and discernement,, not willy - nilly,,
Re: Sig Magnum
« Reply #78 on: May 08, 2013, 05:02:14 PM »
That is a must... Anyway, seen anything you think is not OK?
I'm pretty much done with sanding, gonna go with dope tomorrow. Hope I have enough for a first coat the whole model... ;)
Marcus
Aces High!
Re: Sig Magnum
« Reply #79 on: May 09, 2013, 01:57:49 PM »
Mark,
Do willy and nilly always hang out together? Does nilly sometimes go it alone?
Re: Sig Magnum
« Reply #80 on: May 09, 2013, 08:02:44 PM »
First coat of dope is on...
Marcus
Aces High!
Re: Sig Magnum
« Reply #81 on: May 10, 2013, 09:05:00 AM »
Mark,
Don't forget that they are related to helter-skelter. LL~ LL~
Re: Sig Magnum
« Reply #82 on: May 10, 2013, 09:55:40 AM »
Mark,
actually, Willy and Nilly are interrelated,( please note proper capitalization of the names,, these omissions tend to make Nilly rather upset,, Willy could care less, just give him beer and a lawn chair and he is good), much as Jekyll and Hyde,,
and they have no affiliation with Helter Skelter whatsoever, and will vehemetly deny any such connection or comparisons,,
Offline RC Storick
Re: Sig Magnum
« Reply #83 on: May 10, 2013, 11:32:20 AM »
I always thought Willy and Nilly were related to Heckle and Jekyll?
Re: Sig Magnum
« Reply #84 on: May 10, 2013, 02:18:27 PM »
But not Helter-Skelter.  Possibly a cousin of Flim-Flam.
Re: Sig Magnum
« Reply #85 on: May 11, 2013, 09:33:30 AM »
This is starting to be like the Barton Flying Club site.  They pick on each other also over there.
Offline RC Storick
Re: Sig Magnum
« Reply #86 on: May 11, 2013, 09:44:02 AM »
We are not picking on him! Just joking with flim-flam and willy nilly
Re: Sig Magnum
« Reply #87 on: May 11, 2013, 03:39:35 PM »
You guys forgot Dumb and Dumber LL~ LL~ LL~
Flim Flam does ring a bell though... I wish I knew why... LL~
Aces High!
Re: Sig Magnum
« Reply #88 on: May 11, 2013, 11:55:45 PM »
I'm only picking on Mark, not Marcus.  8)
He's a big boy, he can take it.
Re: Sig Magnum
« Reply #89 on: May 12, 2013, 08:36:25 PM »
Marcus
 Marcus,
 You said above for us to not be shy so I'm going to mention, you're not done sanding yet. n1
 You still have more shaping to do in the areas that Sparky points out with his red arrows above. One example is to compare your rounded edges all around your fin and rudder to the squared and still unshaped ends of the stab and elevator. Looking things over, there are many areas where you can still do more rounding and finish sanding. Shaping details like this should be balanced throughout the entire model. These are the types of details that add just a little more time to a build, but it's spending that time that with the details that can make all the difference in the finished product. As inspiration, I sometimes try to think of it as every stroke of the sandpaper takes off that much more weight too.
 I mean no offense with my comments Marcus, just trying to help you progress... H^^
Re: Sig Magnum
« Reply #90 on: May 13, 2013, 04:29:40 AM »
Wayne
Thanks for your words, and I agree with all of them.
The stab/elev tips are getting rounded for sure.
I'll post pics later.
Good advice is always welcomed... Like, for a first time I'll not pin the hinges.
Marlus is helping me with the painting and clear and he said we should paint everything apart and then glue the hinges, and as everybody here goes like that So will I.
I'll try my best to have a good looking model and learn all I can in the process.
Two things...
I'd still like a pic of that emery board, for I'm not really sure if I know what it is and who the heck is Flim Flam???
Marcus
Aces High!
Re: Sig Magnum
« Reply #91 on: May 13, 2013, 06:36:53 AM »
Marcus,
Not to late to make a change with that weight box.   n~
Looking really good!! Kudos!
Charles
Re: Sig Magnum
« Reply #92 on: May 13, 2013, 03:39:02 PM »
So the Superfil has arrived! Congrats to Brodak for making it come so fast.
Have read the label and run a search here, anyway any tips I could use to get it nice?
I think making a template tool helps a lot, like the radius is smooth and even from the pics I've seen...
Let's see what I get.
Marcus
Aces High!
Re: Sig Magnum
« Reply #93 on: May 14, 2013, 04:02:51 PM »
Marcus,
Just don't worry too much about mistakes. The stuff sands pretty easy and has a very long work time. As much as a couple of hours depending on temperature.
Re: Sig Magnum
« Reply #94 on: May 14, 2013, 04:47:58 PM »
Marcus
Hey Marcus!
I thought you used Epoxy and micro-balloons?
I coppied your moves on that.
Now I gotta copy these moves?   LL~
Hey! Let me know which one you like the best. Probably superfil, it's gotta be lighter? Right?
Charles
Re: Sig Magnum
« Reply #95 on: May 14, 2013, 05:41:39 PM »
Thanks Randy.
Well, most of the top builders use it and recommend it too, so why not?
The epoxi+microballoons works ok, but why not try something different?
It just seems better, and I'll know for sure...
Until the end of the week I shall do the new fillets , then a couple of pics with the wing tips and stab/elev tips sanded to shape.
Gonna buy sandpaper tomorrow... I'm out HB~>
Marcus
Aces High!
Re: Sig Magnum
« Reply #96 on: May 19, 2013, 08:46:38 AM »
Marcus,
HEY! HOW DO YOU LIKE THAT SUPERFIL!!
Wish it was white in color.
Should I toss my micro-balloons?
Charles
Re: Sig Magnum
« Reply #97 on: May 20, 2013, 03:33:06 PM »
I wish it was balsa colored but you can't have everything.
Offline Mike Lauerman
Re: Sig Magnum
« Reply #98 on: June 12, 2013, 05:12:22 PM »
Marcus<<
CAN (and will) someone please send Marcus a pack of emery boards??
Flim-Flam is the 'gremlin' that takes advantage of people's greed and turns it on them. Actor George C. Scott played "the Flim Flam Man" in a 'flim film'. (Whew!)
Re: Sig Magnum
« Reply #99 on: June 12, 2013, 08:47:57 PM »
Thanks Mike
Flim Flam is not related to pufnstuff, is he??
 LL~ LL~ LL~
Marcus
Aces High!
