  • June 16, 2025, 09:31:26 AM
Author Topic: Rustoleum over open bays  (Read 1013 times)
Offline John Castle
  • The Bent Pin
« on: April 14, 2010, 12:26:36 PM »
Will this work over the open bays of a wing?
Medium Silkspan- dope- Rustoleum color coat.
I've done this on solid balsa surface before  but never over open bays.
Also.. Is medium silkspan ok for a .15 sized plane or will the fine silkspan work?
John Castle
McMinnville, Oregon
AMA# 589650
Offline Larry Renger
Re: Rustoleum over open bays
« Reply #1 on: April 17, 2010, 10:22:18 PM »
When I tried that, the finish cracked.  I don't know why.  Only on the open areas, though.  It is just fine over wood.
Offline dennis lipsett
« Reply #2 on: April 19, 2010, 08:03:12 AM »
Interesting,
I've painted over open bays with Rustoleum on several models without any apparent ill effects.Scour surface with fine Scotchbrite and one dust coat and one flow coat and done. After several years they are still good.
Dennis
Offline Leester
« Reply #3 on: April 20, 2010, 05:23:14 AM »
I just covered my Magician 15 with OO silkspan and worked great.
Leester
ama 830538
« Reply #4 on: April 20, 2010, 06:26:58 PM »
Love that airplane, I learned the pattern on one (much to it's detriment).  Try a maneuver, go home, fix, repeat...... HB~>
