  • July 20, 2025, 02:02:03 AM
Author Topic: Prepping plane to prime  (Read 1769 times)
Offline James Holford
« on: August 11, 2017, 07:38:45 PM »
Building pat kings Ringmaster Trainer III. Its profile with plank wing..so lots of balsa.
 Which clear dope should I use to prep the wood to prime?
 I think I read somewhere like 2 light coats of thinned dope then go ahead with the DC540.
Would it be Butyrate or Nitrate?
Not set up to spray so will have to brush it on.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Don Jenkins
Re: Prepping plane to prime
« Reply #1 on: August 12, 2017, 06:00:22 AM »
I would put 3 coats of dope (either, I always use Butyrate) thinned 50%, lightly sand each coat with 360 or 400, cover it with light or medium silk-span, 3 coats of dope, lightly sand each coat, then spray primer.  I know its a trainer, but practice your finishing techniques on it.  As small as it is there is not much area to sand.  Have fun!
Don
« Reply #2 on: August 12, 2017, 06:10:42 AM »
Thanks for the reply Mr. Don!
Its full size Ringmaster lol.
Imagine a beginner Ringmaster with 42" ws lol
Jamie Holford
Lafayette, La
AMA #1126767
Offline Don Jenkins
« Reply #3 on: August 12, 2017, 07:34:48 AM »
It is small compared to a full fuselage, 60 inch span, 680 square inch stunt plane, now that takes a whole lot of sanding!!!
Don
« Reply #4 on: August 12, 2017, 07:38:08 AM »
Oh yea compared to that I agree lol
Jamie Holford
Lafayette, La
AMA #1126767
« Reply #5 on: August 12, 2017, 02:34:50 PM »
James,
Really nice wood work on your Ringmaster. H^^
How did you glue the bottom sheeting on after you did the top?
Charles
« Reply #6 on: August 12, 2017, 02:41:24 PM »
No sheeting.. 3/8 thick sheet lol
Jamie Holford
Lafayette, La
AMA #1126767
