  • June 17, 2025, 09:43:13 AM
Author Topic: Removing dents  (Read 1147 times)
Offline kevin king
Removing dents
« on: August 09, 2018, 03:50:56 PM »
Hi all. Has anyone tried removing a dent from their model while its in silver? I know a dent can be removed by placing a damp cloth on the surface of unpainted wood then heating it with an iron. I have never tried it on silver. I will try it. Worst case scenario is having to use %$#*!#* putty I guess. HB~>
Offline kevin king
Re: Removing dents
« Reply #1 on: August 10, 2018, 01:41:06 PM »
Ty, sorry I missed your reply. I will try your suggestion next time. The iron trick didn't work, so I sanded and filled with that red glazing putty. Its on the outboard wing tip and I sanded most of it off. This is the second last 'Large' airplane I ever build.
Offline kevin king
Re: Removing dents
« Reply #2 on: August 11, 2018, 04:29:19 PM »
That's better
