  • July 17, 2025, 01:56:43 PM
Author Topic: Painting Ultracote  (Read 1569 times)
Online James Mills
Painting Ultracote
« on: June 11, 2015, 07:02:33 PM »
I'm finishing a new plane and am using Ultracote.  I know Rustoleum will work for trim on the wing but I am wondering if the "car" paint (sold at O'Reiliy's) like Dupli-Color would work and maybe have a faster dry time?
James
AMA 491167
Offline Paul Wood
Re: Painting Ultracote
« Reply #1 on: June 12, 2015, 09:07:56 AM »
I have had good results using Duplicolor enamel. Applies just like Rustoleum using a very, very thin coat of primer under the paint. But, I've never tried the lacquer because it requires a fuel proof clear coat. Way too much work for a film covering. At least for me. Make sure you get the enamel and you should have no problem.
