  • July 22, 2025, 05:26:26 PM
Author Topic: Nitrate Shelf Life  (Read 1894 times)
Nitrate Shelf Life
« on: January 29, 2016, 07:03:16 AM »
My Sig Nitrate turned brown in the can, is that bad? I used some on a beater plane and it seemed to work.
Offline dennis lipsett
Re: Nitrate Shelf Life
« Reply #1 on: January 29, 2016, 02:01:18 PM »
I've seen nitrate dope completely brown and dried out in the can. it was revived with thinner? and used apparently with no problems.
Dennis
Offline billbyles
« Reply #2 on: February 01, 2016, 09:56:16 PM »
When nitrate turns amber or brown that indicates it has become more acidic than it should be.  It is a reaction to the metal in the can and air.  I would not use it for a full-scale airplane cover job but you may well get away with it using it on a model.
Bill Byles
AMA 20913
So. Cal.
