  • August 05, 2025, 04:03:31 AM
Author Topic: Nitrate on open bays?  (Read 994 times)
Offline GonzoBonzo
  • GonzoBonzo
« on: December 09, 2012, 05:03:57 PM »
It's been a while since I've covered a model with silkpan.  Back when I did, I used Butyrate exclusively.  I want to try Nitrate, and I've ordered some from Brodaks.  I am pretty sure it's non-taunting.  Can I use this on the open bays of the wing after the silkspan has been applied, or will it not tightend the silkspan enough?
TIA
Gonzo
Gonzo
Re: Nitrate on open bays?
« Reply #1 on: December 10, 2012, 01:45:58 PM »
I use nitrate to attach the silkspan, but then a couple coats of tautening butyrate for the sealing and tightening of the paper.  Everything after that is done with non tautening butyrate.
BIG Bear
RNMM/AMM
Offline GonzoBonzo
  • GonzoBonzo
« Reply #2 on: December 11, 2012, 02:55:36 PM »
Thanks Bill.  Guess I have to buy some butyrate, and thinner.  I thought the paper would be tight enough after it dried.
Gonzo
« Reply #3 on: December 26, 2012, 11:03:21 PM »
I never had a problem with Nitrate shrinking adequately. I'm pretty sure there are low-shrink and high-shrink varieties of both Nitrate and Butyrate, depending on the source.  Be ye careful with Nitrate and a  f~ heatgun in combination.  y1 Steve
