Building Tips and technical articles. => Paint and finishing => Topic started by: GonzoBonzo on December 09, 2012, 05:03:57 PM
It's been a while since I've covered a model with silkpan. Back when I did, I used Butyrate exclusively. I want to try Nitrate, and I've ordered some from Brodaks. I am pretty sure it's non-taunting. Can I use this on the open bays of the wing after the silkspan has been applied, or will it not tightend the silkspan enough?
TIA
Gonzo
I use nitrate to attach the silkspan, but then a couple coats of tautening butyrate for the sealing and tightening of the paper. Everything after that is done with non tautening butyrate.
BIG Bear
RNMM/AMM
Thanks Bill. Guess I have to buy some butyrate, and thinner. I thought the paper would be tight enough after it dried.
I never had a problem with Nitrate shrinking adequately. I'm pretty sure there are low-shrink and high-shrink varieties of both Nitrate and Butyrate, depending on the source. Be ye careful with Nitrate and a f~ heatgun in combination. y1 Steve
