  • June 16, 2025, 04:37:11 PM
Author Topic: Pannel Lines on Monocoat  (Read 1773 times)
« on: March 28, 2018, 11:41:40 AM »
I have searched site and youtube with no luck using every word combination I can think of to answer two questions:
1 - what do you use to put panel lines on monocoat
2 - what clear coat do you seal it with.
Offline Dane Martin
  • heli pilot BHOR
Re: Pannel Lines on Monocoat
« Reply #1 on: March 28, 2018, 11:49:38 AM »
Sooooo, I've done thin cut panel lines with black, grey or white monokote, cut with the monokote pinstriper. A long time ago, I learned they don't exactly hold up forever. So I sprayed over them with Topflite lusterkote crystal clear. They held up great, except if you need to touch up or repair. Then shrinkage is a factor. Otherwise, those Topflite panel line pens with Topflite lusterkote crystal clear worked really good.
« Reply #2 on: March 28, 2018, 01:51:40 PM »
Thanks - Tower still has the pens but nobody appears to have lustercote clear.  Will anything else work?
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: March 28, 2018, 02:26:10 PM »
Currently, I'm liking the clear spray max 2k. I'll be using that on a couple projects soon. I really love these guys for finishing products. They do monokote colors in paint also.
http://www.wingswestrc.com
« Reply #4 on: March 30, 2018, 12:54:00 PM »
I've used pens for Mylar on Monokote to do ink lines and shot catalyzed polyurethane on it. Seems to work OK.
