  • July 12, 2025, 11:32:32 PM
Author Topic: ..Minwax clear lacquer  (Read 1742 times)
Offline Bootlegger
« on: February 28, 2012, 12:51:12 PM »
  Got some Minwax clear lacquer in the Black can, I think that I was told that it is fuel proof.
 What I have in mind is to build a wing using foam, then cover it with silkspan, and brush 3-4 coats of this stuff on it..
Anybody have any suggestions?  Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Steve Helmick
Re: ..Minwax clear lacquer
« Reply #1 on: February 28, 2012, 02:20:46 PM »
If it's really lacquer, it will eat the foam. If it's something else, it may eat the foam. Test beforehand!  y1 Steve
« Reply #2 on: February 28, 2012, 02:29:33 PM »
Hi Gil,
I haven't used or even seen the Minwax lacquer, so let us know how it works.  It would surprise me if it IS fuel proof.
BIG Bear
RNMM/AMM
Offline Paul Wood
« Reply #3 on: February 28, 2012, 03:42:45 PM »
Gil,
I use Minwax clear lacquer all the time.  But, it will eat the foam and is NOT fuel proof.  I've tested it with glow fuel to confirm my suspicions.  I use it just like everyone else uses clear dope.  I don't use dope, but have found this product to work very much the same.  I use it to "glue" silkspan/polyspan, to seal balsa before priming, and mixed with a little talc, makes a good filler coat.  Good product, but not for a top coat.
Offline sleepy gomez
« Reply #4 on: February 28, 2012, 03:52:11 PM »
Yes most paints will eat foam except water based.  There are easy ways to prevent this.  I wrote the  the article in Feb 1974 American Aircraft Modeler.  Call me at 863-899-0656 and I will tell you how.  SLEEPY
Offline Bootlegger
« Reply #5 on: February 28, 2012, 04:03:45 PM »
  Thanks alot guy's, will dope go over the lacquer?
  Again thanks...
 Sleepy, I am in the Central Time Zone, where are you??
Gil Causey
AMA# 6964
« Reply #6 on: February 28, 2012, 04:13:26 PM »
  Again thanks...
Hi Gil,
Dope should go over the lacquer, but test it first.
BIG Bear
RNMM/AMM
« Reply #7 on: February 28, 2012, 09:52:22 PM »
I am in central time zone.  I live in Rising Star Tx about 130 miles west of Dallas.  Call any time between 9:00 am and 11:00 pm.  SLEEPY
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #8 on: February 29, 2012, 09:55:53 AM »
Gil, why don't you just use a low temp film and your worries are over.
         Doug
