  • June 17, 2025, 06:56:38 PM
Author Topic: Filler coat  (Read 1291 times)
Online James Mills
Filler coat
« on: April 08, 2013, 05:37:39 PM »
I'm starting the filler coat on my latest (dope finish).  After I sand the filler coat can I go straight to primer or do I need a coat of clear to seal everything?
James
AMA 491167
Re: Filler coat
« Reply #1 on: April 08, 2013, 05:56:25 PM »
Hi James,
A sealing coat of clear is a good idea.
BIG Bear
RNMM/AMM
Online James Mills
Re: Filler coat
« Reply #2 on: April 08, 2013, 06:55:48 PM »
Thanks Bill.
James
AMA 491167
Re: Filler coat
« Reply #3 on: April 09, 2013, 11:48:50 AM »
Hi James,
BIG Bear
RNMM/AMM
I agree.
Derek
Offline RC Storick
Re: Filler coat
« Reply #4 on: April 09, 2013, 12:54:20 PM »
James
How I do it exactly
2 coats 100% on bare wood
apply covering with 50/50 thinned dope 3 coats Whole model SAND SAND SAND when you think your done sanding sand 3 more times.
2 coats 75% dope 25% thinner
Prime and sand off
light coat of primer whole model
color
trim
Clear of your choice
Offline MarcusCordeiro
Re: Filler coat
« Reply #5 on: April 10, 2013, 10:15:20 AM »
Robert
All dope with a brush, right?
I'll do like you said. I can't go wrong following your lead, can I???
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
