  • June 17, 2025, 06:02:06 PM
Author Topic: EV 3 Finish  (Read 6689 times)
Offline RC Storick
EV 3 Finish
« on: January 18, 2014, 02:35:33 PM »
Here it sits with 1 coat of clear. It was sanded before hand with 400, sanded again and again you get the drift. One coat of clear and sanded again. Tomorrow after applying the second coat I will start covering, Two coats brushed and sanded again with 600. After that it goes to spray only.
As it sits here its 20.3 I am shooting for a six ounce finish but they always end up more. It all depends on how much I want to sand.
Offline RC Storick
Re: EV 3 Finish
« Reply #1 on: January 19, 2014, 01:37:45 PM »
Well its all Covered and 1 coat of dope. I will sand and apply a second tonight. At this stage its 2 ounces lighter than the 55 ounce Viper before it. Of coarse weight don't matter.
« Last Edit: January 19, 2014, 08:12:19 PM by Robert Storick »
Offline MarcusCordeiro
Re: EV 3 Finish
« Reply #2 on: January 19, 2014, 01:42:11 PM »
 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Re: EV 3 Finish
« Reply #3 on: January 19, 2014, 01:56:35 PM »
Looking real good, Sparky!  I really like the "Classic" look of the Vipers!
BIG Bear
Re: EV 3 Finish
« Reply #4 on: January 19, 2014, 10:27:46 PM »
I also like the 'classic' looks of the Viper. And of course, weight matters.  D>K Steve
Offline RC Storick
Re: EV 3 Finish
« Reply #5 on: January 20, 2014, 11:06:48 PM »
I am still sanding. Not much to see yet.
Re: EV 3 Finish
« Reply #6 on: January 20, 2014, 11:32:19 PM »
 Is that leading edge kinda pointy? In the 3/4 front view photo it looks like it gets sharper gradually as it gets closer to the wing root too, does it?
 Thanks for the finishing details.
Offline RC Storick
Re: EV 3 Finish
« Reply #7 on: January 21, 2014, 12:56:45 AM »
Camera plays tricks.
Offline Allan Perret
  • Proverbs
Re: EV 3 Finish
« Reply #8 on: January 21, 2014, 07:25:06 AM »
Good looking bird, you gotta draw some plans.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: EV 3 Finish
« Reply #9 on: January 21, 2014, 09:42:06 AM »
Remember on I-Beam wings you cut the trailing edge of the rib as you put it in place.  Some times  that will throw you a curve as far as the looks of the leading edge.   The plane design looks great Robert aka  Sparky.
Offline Crist Rigotti
Re: EV 3 Finish
« Reply #10 on: January 21, 2014, 09:31:39 PM »
Glad to hear it's 2 ounces lighter than the other one!  You really ought to try Monokote on the wing and stab.  You'll probably save another ounce or two.
Re: EV 3 Finish
« Reply #11 on: January 23, 2014, 06:38:42 PM »
 Pretty sure that ain't gonna happen! :##
 I'm also fairly confident that even speaking the word "Monokote" is taboo in that area of St. Louis. y1
Offline RC Storick
Re: EV 3 Finish
« Reply #12 on: January 23, 2014, 09:12:49 PM »
The canvas is all white now and all together it weighs 51 ounces. I am sure there will be more added. However today the inboard wing had a high rib I just could not deal with. So I tried sanding it and patching the spot. Well that was not satisfactory to me. So on the last try I ripped the covering off the inboard wing ,replaced the rib and re-covered it. Inboard is in clear now and when I catch it up and its white I will post a picture.
No Money-puke on this plane thanks.
Thanks to this mistake I do know what the covering weighs now. .5 ounces per side x4 =2 ounces per wing. Its still gassing off so could be less. But now I know.
Re: EV 3 Finish
« Reply #13 on: January 24, 2014, 05:48:15 AM »
Robert,
If that high rib was on the bottom, would you have made the repair?
Offline RC Storick
Re: EV 3 Finish
« Reply #14 on: January 24, 2014, 06:01:17 AM »
Robert,
Yes
Offline RC Storick
Re: EV 3 Finish
« Reply #15 on: January 24, 2014, 09:25:26 AM »
Well its about a month old and in white. Now comes the hard part. Weight as seen with battery and esc is 51.5 ounces.
Re: EV 3 Finish
« Reply #16 on: January 24, 2014, 10:11:17 AM »
Robert,
What white primer is that you're using?
Aerosol can or spray gun?
Looks good.
Offline RC Storick
Re: EV 3 Finish
« Reply #17 on: January 24, 2014, 10:32:21 AM »
None all dope
Re: EV 3 Finish
« Reply #18 on: January 24, 2014, 01:39:32 PM »
Robert
Is that coat working as primer?? Or it's the painting already??
It looks great!!
Marcus
Aces High!
Offline RC Storick
Re: EV 3 Finish
« Reply #19 on: January 24, 2014, 03:25:20 PM »
Its the white base that is the color.
Re: EV 3 Finish
« Reply #20 on: January 24, 2014, 05:27:47 PM »
Paint over dope, no primer, correct?
Type paint?
Offline RC Storick
Re: EV 3 Finish
« Reply #21 on: January 24, 2014, 09:41:51 PM »
White dope over clear dope
Offline RC Storick
Re: EV 3 Finish
« Reply #22 on: January 25, 2014, 09:10:24 AM »
Well I am thinking the paint scheme will be the same as my Continental RWB stripes. My Continental is 8 years old and while it still fly's well I will need a replacement. So it shall be.
Offline 55chevr
Re: EV 3 Finish
« Reply #23 on: January 25, 2014, 11:56:07 AM »
I always liked that paint scheme ...
Joe Daly
Offline RC Storick
Re: EV 3 Finish (pic)
« Reply #24 on: January 27, 2014, 06:17:45 PM »
My batteries died and I only got one shot but this is where I am at in under 30 days. I have a few small spots to re-sand and repaint white but all in all this one came out good. Its light and straight. All the left is do the few small touchups and paint numbers and few decals then ink and clear. (I forgot the nose art) Unfortunately its 54 ounces as seen here so it should come in around 55.5- 56.5. I don't quite understand why as all the sub assembly's were lighter than the one before it and it has approximately the same amount of paint on it.
Take away the battery and its 45 ounces for a 700 square inch airplane. Should be fine.
No I don't sleep much.
and I have built more than a few
Re: EV 3 Finish
« Reply #25 on: January 27, 2014, 06:22:53 PM »
Robert,
Are these colors dope also?
You can sleep next month.
Offline RC Storick
Re: EV 3 Finish
« Reply #26 on: January 27, 2014, 07:13:29 PM »
Robert, Are these colors dope also?
As has been stated the best results come from using all the same products. I started with dope and everything after will be dope. JFYI I have not found any paint lighter.
« Last Edit: January 31, 2014, 02:15:45 AM by Robert Storick »
Re: EV 3 Finish
« Reply #27 on: January 27, 2014, 07:16:35 PM »
 That's really light for a 700 inch model, I sure wouldn't be complaining.
 I like the clean scheme and I'm anxious to see it with the rest of the color, and I hope you're out of yellow. :##
Re: EV 3 Finish
« Reply #28 on: January 28, 2014, 07:52:59 AM »
Nice!!!
Marcus
Aces High!
Offline RC Storick
Re: EV 3 Finish
« Reply #29 on: January 28, 2014, 10:52:01 AM »
well its gassed off .5 oz so I am back to 53.5 SO I am looking at 55 total.
Re: EV 3 Finish
« Reply #30 on: January 29, 2014, 08:35:28 PM »
 Done yet?  ;D
Offline RC Storick
Re: EV 3 Finish
« Reply #31 on: January 31, 2014, 01:47:18 AM »
Not done yet. Here is today's progress. I had to build this work bench and clean up a little before going any farther. Shop is clean enough for the next 5 planes.
Tomorrow I am off to the sign shop for some stencils and then paint the remaining lettering . It will be on to ink and clear. But its less than a month old.
I added some shots of the electric mounting and setup.
« Last Edit: January 31, 2014, 02:13:16 AM by Robert Storick »
Offline Doug Moon
Re: EV 3 Finish
« Reply #32 on: January 31, 2014, 07:26:46 AM »
The plane is looking good!!!!!!
Congrats on another well done model!
The shop looks nice too.
How is it that as you build more you get faster but as I build more I get slower....??
I think you have a twin brother we don't know about who comes over and works the day shift and you work the night shift....
I also noticed this one doesn't have the vertical battery.  But this one is recessed into the wing.  I do the same thing with my planes, cut back the LE 1" or so to move the tank back.
I really like that plane.  When did you design the first one?  Is it classic legal?
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
Offline RC Storick
Re: EV 3 Finish
« Reply #33 on: January 31, 2014, 11:49:20 AM »
I started building this design around 1985 and there is no documentation until 91, So its not classic legal. It has been built in many configurations different wings and construction methods. I like this wing best. I beam and low aspect.
Re: EV 3 Finish
« Reply #34 on: January 31, 2014, 12:04:48 PM »
You build and finish such gorgeous airplanes.
Offline RC Storick
Re: EV 3 Finish
« Reply #35 on: January 31, 2014, 12:40:39 PM »
Thanks Doc now all I need is flight time and a coach. This is my last try to make top 20.
Eggs are not loops.
Re: EV 3 Finish
« Reply #36 on: January 31, 2014, 02:07:56 PM »
Sparky, I really like the paint scheme!  It fits just right onto that model.  I wish I could come up with good paint schemes.............  Just don't overdo the ink, and it will be very "classy"!
BIG Bear
Offline Duke.Johnson
Re: EV 3 Finish
« Reply #37 on: January 31, 2014, 02:16:44 PM »
Sparky, I'm going to steal that paint scheme for my next Cavalier.  y1 #^ H^^
I really like the nose scheme.  I remember you doing something like that last year on another model.  Someday I'll try it on a plane.  Great job, again!
Offline RC Storick
Re: EV 3 Finish
« Reply #38 on: January 31, 2014, 02:22:52 PM »
All the lettering is done. Today I will shoot a coat of clear to seal things then ink and 2 more coats of clear. I am thinking that should be done around the fifth of February and that will be exactly 30 days. I wonder how it will do in appearance judging.
It is light, it should come in at 55 ounces. Seems with a plane this size I just cant make them any lighter. Too much fixed weight. If anyone thinks its a easy task to hit this weight and still have  a presentable model please give it a try.
Re: EV 3 Finish
« Reply #39 on: January 31, 2014, 02:49:04 PM »
The best I could do was 62.5 oz. Maybe I could get it to 60 even on the next one but I have been too busy to try. Good job Sparky, it looks good and should fly good.
Derek
Re: EV 3 Finish
« Reply #40 on: January 31, 2014, 05:27:35 PM »
Another masterpiece by Robert.
Marcus
Aces High!
Re: EV 3 Finish
« Reply #41 on: January 31, 2014, 05:31:29 PM »
Robert,
Looking at those interior construction photos, you could perform surgery in there. Organized, clean and simple.
How wide is it in that space, or, what is the widest interior measurement inside your fuselage?
Offline RC Storick
Re: EV 3 Finish
« Reply #42 on: January 31, 2014, 05:43:09 PM »
Robert,
On this one its 2.5 I.D.
Re: EV 3 Finish
« Reply #43 on: January 31, 2014, 07:11:27 PM »
 Looks great Sparky, nice and clean. Are you still going to paint the wheelpants though?
Offline Serge_Krauss
Re: EV 3 Finish
« Reply #44 on: February 01, 2014, 12:19:48 AM »
A very elegant model and I don't need to restate the obvious, but beautifully crafted.
SK
Offline RC Storick
Re: EV 3 Finish
« Reply #45 on: February 01, 2014, 06:48:36 AM »
Derek
I would like to state this is 55 fueled so if I took the average 6 ounces off for the IC fuel ,its a 49 ounce plane.
Airframe less hardware is 25 ounces painted.
Re: EV 3 Finish
« Reply #46 on: February 01, 2014, 09:03:28 AM »
Hey Sparky I thought you had a good coach.   I know you have some great judges down/over there.  Just have to remember to not get upset when they tell you what you are doing wrong.   I have received help on  my flying and try to correct my flying, but my excuse and I'm going to stick with it, is I don't  fly enough.  Do you have the critic sheets for someone to use while watching you fly?  Be really great if you had a NATS judge to help you.  I know  it is hard in that doing the simple inside loops you think you are nice a round and on top of each other, but what does it look like outside the circle to the judge? H^^
Re: EV 3 Finish
« Reply #47 on: February 01, 2014, 09:07:16 AM »
The loops  should  look  ROUND to the PILOT......    nice  job Sparky, plane looks  very good
Offline George Grossardt
Re: EV 3 Finish
« Reply #48 on: February 01, 2014, 10:56:01 AM »
Outstanding looking aircraft.  Can't wait to hear how it flies.
Offline RC Storick
Re: EV 3 Finish
« Reply #49 on: February 02, 2014, 01:24:35 PM »
Here is the totals. E Viper 2 weighs 54.45 with a 2826/12 and E Viper 3 weighs 55.10 with the bigger 3515/18. So I would say they came in at the same weight. This one is finished just short of a month. I have so much time left I might build another one.
