  • August 03, 2025, 06:33:38 AM
Author Topic: Offbeat clearcoat question  (Read 2096 times)
« on: March 10, 2009, 12:36:05 PM »
I was reading a thread about Allen's Olympus (I think on SSW) and he said that he used iron plastic on the flying surfaces and shot the whole plane with clear (catalyzed poly, I think). Anyway, it's wasn't clear (sorry for the pun) exactly what was used. How is this done? Do you have to rough up the iron-on first? Use steel wool on it or something. I can't imagine you'd get much of a bond otherwise.
Any information on the technique of shooting a clear coat over iron on?
Offline Allan Perret
  • Proverbs
Re: Offbeat clearcoat question
« Reply #1 on: March 10, 2009, 05:44:41 PM »
I pulled this from a 2nd thread about the Olympus.
"Well, I have weighed the Olympus tonight. I gained two ounces using the Nason (DuPont) clear coat. I added one medium coat of the Nason and mixed as stated on the can."
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: March 10, 2009, 06:02:25 PM »
Allan,
Yea, I got that part (went back an looked myself). It didn't' seem that there was any special surface prep except making sure it was clean. Something I may try.
Offline CharlesF
« Reply #3 on: March 29, 2009, 10:28:01 AM »
I put the color trim on my Thunderbird flying surfaces (plastic) with stuff called "RC Colours" from a spray can (made in Belgium) It stuck fine and that's 3 years ago. Plastic wasn't Monokote but "suprcoat" or some such name.
Charles
« Reply #4 on: March 29, 2009, 11:51:28 AM »
I'm interested in this too, I've tried clear dope over film, but a single scratch and the dope comes off in sheets even if the film was roughed up. Sure looks good though.
« Reply #5 on: March 30, 2009, 03:34:29 PM »
RAndy,
I'm told it's because dope dries too hard. There would be no chemical bond, after all. I may try it on this current plane with catalyzed polyurethane, but probably not. I will try overlapping the clear I plan to shoot on the fuse over the edge of the plastic covering and see how that works.
