  • June 16, 2025, 04:26:34 PM
Author Topic: polishing compounds ?  (Read 2135 times)
Offline Alan Buck
« on: April 01, 2011, 03:04:35 PM »
Which polishing compound is the better to use on the types of finishes we use? I used Brodak dope with a DuPont clear 480s which is a Acrylic. Thanks
ALAN E BUCK
Re: polishing compounds ?
« Reply #1 on: April 01, 2011, 04:09:04 PM »
Well, I use 3M polishing compound and 3M finishing compound (both liquid) then finish off with something like Maguire's mirror glaze or similar.
Offline Alan Buck
« Reply #2 on: April 01, 2011, 10:16:46 PM »
Thanks, Randy
ALAN E BUCK
« Reply #3 on: April 01, 2011, 10:24:29 PM »
I use exactly what Randy uses.
I Machine buff with a zero buffing foam Pad with Dual Action buffer.
« Reply #4 on: April 02, 2011, 10:17:59 AM »
Yup, same here. Although, I use it on Randy's recommendation. I also have some silver polishing paste that comes in handy.
« Reply #5 on: April 02, 2011, 07:00:18 PM »
Brasso after a good 2000 grit sanding, no swirl remover required.
Online Howard Rush
« Reply #6 on: April 02, 2011, 09:35:08 PM »
With PPG Duracryl DCA468 acrylic lacquer I use Meguiar's #2, then #9, then #7, all by hand.  The catalyzed polyurethane requires different stuff.
Online Howard Rush
« Reply #7 on: April 02, 2011, 09:37:57 PM »
Which numbers?
« Reply #8 on: April 02, 2011, 11:07:33 PM »
Numbers # 1 and then 2 .. Never by hand - always with a Dual action buffer set to 1400 rpm for final coats.
I also use the Menzerna Final Finish PO85U which is for removing 3000 grit swirls.
Cant knock howards technique - its always front row - I just don thave that sort of time to finish a model - 4 - 6 weeks is all I want to spend.
« Reply #9 on: April 02, 2011, 11:11:37 PM »
 I spray the clear on and let it dry. ;D :##
