  • June 16, 2025, 11:30:43 PM
Author Topic: Todays progress (pics)  (Read 4744 times)
Offline RC Storick
« on: February 14, 2013, 10:46:03 PM »
I spent most of the day doing the clean battery install. Super meticulous very small cramped spaces. I am still detail sanding. If I don't make front row it wont be from the lack of trying. I do however see a military scheme in the works as it would be lighter and with the plane together I can better keep a eye on its weight. It'd creeping up and you don't know where its coming from. Funny.
« Last Edit: February 15, 2013, 12:57:39 AM by Robert Storick »
Offline Alan Resinger
Re: Todays progress (pics)
« Reply #1 on: February 15, 2013, 04:08:43 AM »
Sparky,
Looking good.  Curious about the small knob behind your timer switch.  What is that?
Alan Resinger
Offline RC Storick
« Reply #2 on: February 15, 2013, 08:52:03 AM »
Sparky,
Alan Resinger
Electric needle valve. Adjust RPM 500 up -down 250 each way
Offline Dave Denison
« Reply #3 on: February 19, 2013, 09:56:14 PM »
Sparky
How are you coming out on the "paint and weights"?   I see you have color on the Crossfire, now it gets interesting.
ama41041
ama 41041
Offline RC Storick
« Reply #4 on: February 20, 2013, 09:32:57 PM »
Sparky
ama41041
Paint weight is right on target. As you see it here 57 OZ. I don't think I will add more than 3 oz in the finish in trim and clear. Unfortunately I will not be using urethane,(well I might) just clear dope.
« Reply #5 on: February 20, 2013, 10:21:33 PM »
 Lookin' good so far Sparky! y1
 Obviously there's a lot more coming yet, but are you going to extend the red graphic in front of the canopy too?
Offline MarcusCordeiro
« Reply #6 on: February 21, 2013, 07:24:11 AM »
That looks terrific!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline RC Storick
« Reply #7 on: February 21, 2013, 08:39:40 AM »
progress is slow because I am painting RED. I hate using read as a trim color because the tape job has to be perfect. Red will find anywhere to bleed. So if you are using read as a trim color take heed and tape well.
My choices are all about weight. I am using doors instead of pants because they weigh only 4 grams each. I choose grey to use less paint. I have found the the wire in this plane is extremely heavy and I will shorten them up. A 2 inch jumper wire is 6 grams. so there is a foot of wire in the plane and if I can take out 6 inches that's a half ounce.
« Reply #8 on: February 21, 2013, 08:58:11 AM »
You are absolutely correct about red. It does not matter how carefull I am I always have a blow through somewhere. Looks good Spark, keep it up. Don't worry about the doors, Howard makes the front row every year with wire gear.  VD~
Derek
Offline RC Storick
« Reply #9 on: February 21, 2013, 09:27:47 AM »
Derek
I dont see front row this year. No paint
« Reply #10 on: February 21, 2013, 10:09:10 AM »
Ink does not weigh anything!!!! ;D
BTW do you need paint masks?
Derek
« Last Edit: February 21, 2013, 10:19:44 AM by Robert Storick »
Offline RC Storick
« Reply #11 on: February 21, 2013, 10:19:56 AM »
I would like a couple of these for the rudder.
« Reply #12 on: February 21, 2013, 11:08:19 AM »
That would be a pretty complicated 3 step mask. I would have one of the ink jet printer guys make you those.
Derek
Offline RC Storick
« Reply #13 on: February 21, 2013, 01:33:33 PM »
Derek
OK how about this?
this is a easy one
  • Gravitywell
« Reply #14 on: February 21, 2013, 01:41:02 PM »
Actually, I really like the scheme the way it is.  I'm a basic, uncluttered (except my work table!) kind of guy.  Its simple and good looking. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #15 on: February 21, 2013, 02:56:16 PM »
Hey Sparky,
I am sure I could handle either one of those. Just let me know.
Derek
« Reply #16 on: February 21, 2013, 03:56:46 PM »
You are absolutely correct about red. It does not matter how carefull I am I always have a blow through somewhere. Looks good Spark, keep it up. Don't worry about the doors, Howard makes the front row every year with wire gear.  VD~Derek
You could spray the taped edge with a quick coat of clear to seal the edge.
Then shoot the color. Prevents bleeding. Well, it should.  n~
Charles
Offline RC Storick
« Reply #17 on: February 21, 2013, 04:43:23 PM »
Charles
I get no bleed under the tape. It the areas that are not tapped that pick up red dust.
« Reply #18 on: February 21, 2013, 06:00:45 PM »
Sparky
Outstanding so far, as Glenn said in a previous post, keep it simple, keep it clean. Are you going to use a third trim color, if so, what will it be? To save weight on mine I also used wheel spats as opposed to making more elaborate wheel pants and down legs.  The lines of the Crossfire lend themselves to long flowing clean lines down the fuselage. I do like your last two Sparky Logos that you've shown, I have not found an interesting one to put on my FinessE at this point.
Keep the ideas and the pictures coming, looks like your weights should be well within the ballpark. Here is a side shot of mine, giving you some ideas for flowing the colors and the long lines that the Crossfire shows off well.
ama 41041
ama 41041
« Reply #19 on: February 21, 2013, 07:57:49 PM »
 HA! "Ready Kilowatt" would be super cool Sparky, you gotta find a way to make it happen. y1 ;D
Offline Crist Rigotti
« Reply #20 on: February 21, 2013, 09:06:40 PM »
How about using a decal of ole Ready!
Offline RC Storick
« Reply #21 on: February 21, 2013, 09:25:10 PM »
Been searching for a hr for a water slide decal but can't find one yet. I might have to buy a inkjet printer and paper
It's creeping as it sits here 58 OZ. No tip weight or clear.
« Last Edit: February 21, 2013, 09:45:09 PM by Robert Storick »
« Reply #22 on: February 21, 2013, 11:30:18 PM »
A Smokey the Bear decal might be another option.   LL~ Steve
"Only YOU can prevent electrical fires!"
Offline RC Storick
« Reply #23 on: February 22, 2013, 02:29:53 PM »
I would like to publicly thank Wil Hubin for his great service and products. He sent me at no charge a new FM9 timer ever though I was the one responsible for the damage to the first one.
Offline RC Storick
« Reply #24 on: February 22, 2013, 03:12:04 PM »
today I added 1 OZ of tip weight bringing the grad total to 1680 grams. 59.25 with clear left to go. So I don't think I will make under 60 OZ but should make under 62 with clear. That's 2.25 oz of clear paint. I hope I can do it in 1 but I know me Bet I can't. For some reason there is something about a slick shiny airplane that draws me to finish that way even though I know better. If you want it light you can't add paint.
Offline RC Storick
« Reply #25 on: February 22, 2013, 03:53:27 PM »
I just got a volunteer "John" is going to make me 2 decals like this for the rudder
« Last Edit: February 22, 2013, 09:28:35 PM by Robert Storick »
Offline Steve Fitton
« Reply #26 on: February 22, 2013, 04:56:02 PM »
the white parts of the decal will be hard without an ALPs printer...
« Reply #27 on: February 22, 2013, 06:40:45 PM »
Depending on the size, they could be made out of vinyl and layered for the different colors.
Cutters can only do so much when things get small. Blade and all.
I do have a wholesale printer that does my full color.
Charles
Online RandySmith
« Reply #28 on: February 22, 2013, 07:00:41 PM »
Just put the decals  over the white painted base  and you will not have to worry about  it
« Reply #29 on: February 22, 2013, 08:31:14 PM »
Charles
Charles,,
you kinda miss the point with a stunt ship,, every gram matters,, adding enough clear to blend the thickness of a vinyl sticker adds weight in the worst possible place,, on the tail,,,
also, my small little ameture home cutter would cut that design with no problem at all, I have done lettering down to a quarter inch before,, that design has thickness and no real areas of concern except for the multicolor,,,
« Reply #30 on: February 22, 2013, 08:43:04 PM »
Charles,,
If this is the one that's coming out nose heavy, then extra weight on the tail isn't going to be a big problem.
Unless Sparky's fixed the nose heavy problem.
Offline RC Storick
« Reply #31 on: February 22, 2013, 08:53:26 PM »
I never want to add weight I would rather removed it from the nose.
Offline RC Storick
« Reply #32 on: February 23, 2013, 11:12:44 AM »
Logo for the wing
« Reply #33 on: February 23, 2013, 12:11:09 PM »
Charles,,
Mark,
I never mentioned clearing the vinyl sticker. I don't recommend it.
Charles
  • Gravitywell
« Reply #34 on: February 23, 2013, 12:32:35 PM »
That wing logo looks awesome! H^^
Glenn Reach
Westlock, Alberta
« Reply #35 on: February 23, 2013, 06:18:11 PM »
Mark,
Charles
in order to get the appearance we desire for STUNT competition, clear would be necessary both for a smooth glossy finish, and fuel proofing the vinyl,, so by referring to layering, you meant multiple layers of vinyl,, not clear over the vinyl,, that makes it worse,, not better,,
Paint would most generally be prefered,, its much lighter than vinyl,, and much more attractive,,
anyway, back to sparky's build,, sorry for the hijack Robert,,
simple and clean so far,,
« Reply #36 on: February 23, 2013, 06:42:37 PM »
Well, fuel proofing isn't necessary, but the thing does need to be durable and you have to clean it.
« Reply #37 on: February 23, 2013, 06:51:59 PM »
I dont know Randy, some of them people in the Pits are kinda sloppy when they set their needle,,,,  HB~>
« Reply #38 on: February 24, 2013, 08:34:19 AM »
Yeah, we need a rule against running engines in he pits.  Have lost cont many times I have seen people running engines with the exhaust blowing all over other peoples planes.
Offline RC Storick
« Reply #39 on: February 24, 2013, 09:21:16 AM »
a little closer. I am debaiting on yellow and black or red white and blue as trim colors. Or black and white checkerboards
Offline RC Storick
« Reply #40 on: February 24, 2013, 02:02:20 PM »
side view
« Last Edit: February 24, 2013, 03:41:29 PM by Robert Storick »
« Reply #41 on: February 24, 2013, 02:56:47 PM »
The more I see it, the more I like it... :)!
Marcus
Aces High!
Offline RC Storick
« Reply #42 on: February 24, 2013, 03:30:23 PM »
Marcus
Wattman on the rudder. How cool is that?
« Reply #43 on: February 24, 2013, 03:59:22 PM »
Looks good, Sparky!  H^^ Steve
« Reply #44 on: February 24, 2013, 06:01:22 PM »
Very cool Robert, I'd say "shocking"... #^ #^ #^
Marcus
Aces High!
« Reply #45 on: February 24, 2013, 07:09:16 PM »
Looks very cool, Robert. Couple of guys build Crossfires up here. They are nice flying planes.
Offline John Jordan
  • Balsadust
« Reply #46 on: February 25, 2013, 04:00:31 AM »
you need yellow & black to go with watman & crossfire logos
John Jordan    ama # 5939
« Reply #47 on: February 25, 2013, 12:22:20 PM »
 Two cents here Sparky...
 Glad to see the red added on the nose. I think it needs the thin red line on the wings and stab to match the fuse. From there I guess I'd think about somehow adding some blue. Maybe the blue on the bottom third of the fuse with a big "USA" or something over the grey in between the red and blue. Don't make "Reddy" feel like you have to add more yellow to the scheme just because of him being on the tail, he'll be just fine as is. ;D
« Last Edit: February 25, 2013, 04:48:45 PM by wwwarbird »
« Reply #48 on: February 25, 2013, 01:54:06 PM »
Not to mention a pilot who came up to me at the NW Regionals last year and muttered "my fuel line just slipped off my syringe, and I squirted fuel all over an electric plane" before gathering his courage and going to find the owner.
Electrics still need fuel-proof finishes, or at least finishes that are fuel resistant enough to take the occasional accidental dribble or squirt, or blast from an engine exhaust.
« Reply #49 on: February 25, 2013, 02:45:07 PM »
I'm really glad you went with Wattman on the rudder, that's perfect!!
