  • July 20, 2025, 12:48:35 AM
Author Topic: Brodak White Primer question...  (Read 2595 times)
« on: March 09, 2015, 06:43:26 PM »
 I've got some Brodak White Primer that I'm thinking of trying out for the first time. The plan is to use it to create a uniform base for a yellow topcoat. I'd like to know ahead of time though, when dry does it sand easily like a typical grey rattle can primer or does it dry more to a harder finish like regular dope?
Offline Allan Perret
  • Proverbs
Re: Brodak White Primer question...
« Reply #1 on: March 09, 2015, 07:33:50 PM »
Its sands very easy, just like the DC540.  You will fill your shop with white snow, make sure you wear a mask or you will probably get a headache.  But just like most primer/fillers it builds weight fast.  Only leave the bare minimum to get your white base, which you do need for yellow.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #2 on: March 09, 2015, 07:48:51 PM »
Just used it myself Wayne....sands easily.
« Reply #3 on: March 13, 2015, 10:46:44 PM »
 Well, I've tried the stuff out. It's really thick out of the can, got a funky smell to it too. I thinned mine a lot, probably about 75/25 thinner/primer and sprayed it with my detail gun. It sprayed and covered well, but I don't feel that it sands as easily as the DC540. My feeling was that it's not as hard a finish as dope, but it's close. My opinion? I like the DC540 much better, too bad it doesn't come in white. D>K
« Last Edit: March 14, 2015, 04:34:17 PM by wwwarbird »
« Reply #4 on: March 14, 2015, 10:00:42 AM »
Hi Wayne,
I haven't bought any in a while, but I am sure Duplicolor still makes a white primer which is similar to DC540.  I used it for a blocking coat under light colors.  It covers well and sands easily.  I get it at NAPA.
BIG Bear
RNMM/AMM
« Reply #5 on: March 14, 2015, 04:36:22 PM »
  Thanks Bill, that might be something to keep in mind. I'm fine with grey primer, except under yellow.
« Reply #6 on: March 15, 2015, 06:43:25 PM »
Primer weighs too much,
« Reply #7 on: March 15, 2015, 07:50:09 PM »
 I agree. The main reason I tried it here though was to achieve the white basecoat for the yellow. I was also curious about how the product worked. Figured it would be a toss-up weightwise between it and a good solid basecoat of white dope. I'll be back to my normal no primer routine next time. D>K
