Building Tips and technical articles. => Paint and finishing => Topic started by: wwwarbird on March 09, 2015, 06:43:26 PM
I've got some Brodak White Primer that I'm thinking of trying out for the first time. The plan is to use it to create a uniform base for a yellow topcoat. I'd like to know ahead of time though, when dry does it sand easily like a typical grey rattle can primer or does it dry more to a harder finish like regular dope?
Its sands very easy, just like the DC540. You will fill your shop with white snow, make sure you wear a mask or you will probably get a headache. But just like most primer/fillers it builds weight fast. Only leave the bare minimum to get your white base, which you do need for yellow.
Just used it myself Wayne....sands easily.
Well, I've tried the stuff out. It's really thick out of the can, got a funky smell to it too. I thinned mine a lot, probably about 75/25 thinner/primer and sprayed it with my detail gun. It sprayed and covered well, but I don't feel that it sands as easily as the DC540. My feeling was that it's not as hard a finish as dope, but it's close. My opinion? I like the DC540 much better, too bad it doesn't come in white. D>K
Hi Wayne,
I haven't bought any in a while, but I am sure Duplicolor still makes a white primer which is similar to DC540. I used it for a blocking coat under light colors. It covers well and sands easily. I get it at NAPA.
BIG Bear
RNMM/AMM
Thanks Bill, that might be something to keep in mind. I'm fine with grey primer, except under yellow.
Primer weighs too much,
I agree. The main reason I tried it here though was to achieve the white basecoat for the yellow. I was also curious about how the product worked. Figured it would be a toss-up weightwise between it and a good solid basecoat of white dope. I'll be back to my normal no primer routine next time. D>K
