  • July 17, 2025, 12:04:35 AM
Author Topic: Bill Byles & Randy Powell  (Read 1213 times)
Offline Bootlegger
« on: September 25, 2013, 02:29:32 PM »
  When you are using clear dope over the colors what is your thinner/dope ratio, and what pressure do you use if using a HVLP paint gun?
  The dope is Sig Lite Coat clear, and I am spraying two coats per day at 20-22 lbs at the gun.
 It was blushing yesterday, so today I added about 2% retarder.
  I am also thinning the clear 60% thinner 40% dope.
  Thanks for your advice...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Bill Byles & Randy Powell
« Reply #1 on: September 25, 2013, 04:50:33 PM »
Well, you'd want to shoot the clear with the humidity is somewhat down. But the mix sounds about right. Depends on the HVLP gun. I shoot mine (SATA for clear) with about 15lbs continuous.
