  • June 15, 2025, 01:37:36 AM
Author Topic: Best Iron On Covering  (Read 7382 times)
Offline David_Ruff
  • David Ruff
  • Retired Army
« on: November 08, 2023, 11:19:58 AM »
I am removing the fake silkspan from my Goldberg Shoestring wing.  I am sanding it well.  If there is some fake silkspan on the L.E. and T.E. will an iron-on work if that surface is well sanded?
Just glad to be here
Re: Best Iron On Covering
« Reply #1 on: November 08, 2023, 12:32:03 PM »
Dave,
You can use a heat gun to get the last bits of covering off and a somewhat dull knife blade to scrap a bit followed by medium sand paper. Once smooth if using an iron covering I give a coat of Balsarite for film to the surface. This seal a bit and give strong adhesion but will not causes bubbles in the film.
What film are you using?
Best,   DennisT
Offline Colin McRae
  • Are we having fun yet??
« Reply #2 on: November 08, 2023, 12:34:14 PM »
As you are doing, I have recovered old silkspan wings w/ Monocote. But I have also used a product called Cover Grip which is a heat-activated brush-on glue designed to work w/ iron-on coverings. It also helps iron-on covering adhesion on oil-soaked wood areas.
On any suspect oil-soaked areas, I first treat the area w/ K2R cleaner, let dry, then sand the area.
I also prefer the Top Flite Monocoat covering vs other brands on the market. But just my opinion.
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #3 on: November 08, 2023, 01:14:27 PM »
I have no problems with oil soaked wood.  Currently I have a roll of Ultracote.  I have used Ultracote and I can work it pretty well.
I never used Monokote.
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #4 on: November 09, 2023, 08:14:57 AM »
So I am trying the transparent Ultracote.  So far so good.  Never mind the ugly frame.
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #5 on: November 09, 2023, 10:24:23 AM »
monokote is the way to go. the red on wings and tail is monokote
i have used oracover for almost a decade but dound out later that it tends to delaminate after some 5-7 years
have monokoted planes for clients with more than 20 years of active flights still looking good.
« Reply #6 on: November 13, 2023, 06:42:02 PM »
So, with MonoKote gone besides Ultracote what other film brands are still available and from who?
Best,   DennisT
Offline David_Ruff
  • David Ruff
  • Retired Army
« Reply #7 on: November 14, 2023, 02:44:51 PM »
Well here is the Shoestring.  Just a beater/trainer.  Removed the old silkspan and covered in Ultracote.
« Reply #8 on: November 15, 2023, 06:36:25 AM »
I've used them all.
Top Flite Monokote is the strongest and heaviest and it takes the most heat and cannot be used on foam.
All the others are lighter and less strong and take lower temperatures and generally can be used on foam.
They all work.  The tradeoff of weight vs strength is for you to decide.
At this time any film any color is the best you can do.
This plane used several brands of lightweight low temp film over bare foam.
Offline Larry Renger
« Reply #9 on: December 03, 2023, 05:12:40 PM »
If warp resistance and strength are an issue, look into the SLC over Polyspan thread. I have used this technique for over a decade with fantastic sucsess, as has, at least Doc Holliday. Others have used it too. Over 58,000 hits on the thread, so there must be something going for the technique.
I hope more individuals will discuss use,failure, but they seem shy. 🤠
Actually I would welcome on the downside so maybe the technique could stand some improvement.
