Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
August 01, 2025, 03:08:46 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Paint and finishing
(Moderator:
RC Storick
"new" covering material?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: "new" covering material? (Read 6781 times)
Jim Oliver
25 supporter
Trade Count:
0
Admiral
on:
September 23, 2023, 06:14:07 PM »
Some time ago I read something about using medical exam table covering paper to cover wings etc.
My Dr. gave me a roll so I'm interested in trying it.
Have any of you tried it and how did it work out?
Jim
Logged
Jim Oliver
AMA 18475
25 supporter
Trade Count:
0
Admiral
Re: "new" covering material?
Reply #1 on:
September 23, 2023, 08:50:33 PM »
Just search on the forums for "Docspan", "exam table paper" Tidi, and you should come up with about 5 hours worth of reading, at a minimum!
Logged
EAA 1038824
944_Jim
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
September 24, 2023, 06:06:15 AM »
Mr. Jim,
In short, you want the type known "everyday crepe." It has a very similar porosity and finish as typical paper of days gone by. It shrinks well in BOTH DIRECTIONS. My experience is with 1/2A models...I noted a heavily crowned wing will need some extra stringers between the LE and the "crest of the airfoil" across the wing to prevent pulling down between the ribs.
Tidi part number is #981004 (22" wide roll) or Tidi #981002 (18" roll). McKessen is another brand. Tidi and McKessen used to have the same last 4 digits in their respective line).
Key words should have "every day crepe" in the description regardless of vender. Be careful with high-shrink dope on smaller surfaces...pm your email address if you want pictures showing what I mean. Or find my Brown-Novitnik DH Mosquito build on RCGroups or CoxEngineForum...same username as I use here.
I strongly recommend building a cheesy 4 or five rib "wing section" to test on before you dedicate time on this stuff on your model.
Your research should start here:
https://stunthanger.com/smf/open-forum/world-shortage-of-silkspan-ended-frank-d-nominated-for-'hero-of-the-reich'/
Logged
Jim Oliver
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
September 24, 2023, 07:27:04 AM »
Thanks!!
Jim
Logged
Jim Oliver
AMA 18475
Larry Renger
21 supporter
Trade Count:
0
Admiral
Reply #4 on:
December 03, 2023, 05:18:09 PM »
If excessive shrink is a problem,spray with common rubbing alchol instead of water. Water content is low and it dries quickly.
Logged
BTW, Dracula Sucks! A closed mouth gathers no feet!
Dwayne Donnelly
24 supporter
Trade Count:
0
Captain
Balsa Beavers Toronto Canada
Reply #5 on:
December 04, 2023, 04:55:52 PM »
Quote from: Larry Renger on December 03, 2023, 05:18:09 PM
If excessive shrinkage is a problem
Stay out of the pool.
Logged
Luke N.
24 supporter
Trade Count:
0
New Pilot
Reply #6 on:
December 04, 2023, 11:37:06 PM »
Hmmm..... it seems that reply 5 reminds me of a Sienfeld episode.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Paint and finishing
(Moderator:
RC Storick
