  • July 31, 2025, 03:57:13 AM
Author Topic: 2K Clear Over Canopy  (Read 2718 times)
Offline jfv
« on: April 20, 2023, 08:40:36 PM »
Has anybody tried 2K clear over a plastic canopy?
Jim Vigani
Rick_Huff
Re: 2K Clear Over Canopy
« Reply #1 on: April 21, 2023, 05:55:01 AM »
Yes.
I've never run into a problem with it.
Rick
« Reply #2 on: April 21, 2023, 08:05:42 AM »
JFV,
Before you spay over your canopy take a small piece of the canopy flashing material and do a test with the 2K you are going to use to make sure it doesn't melt. Different canopy materials can be affected by the reducer in the 2K, most are OK.
Best,   DennisT
Offline jfv
« Reply #3 on: April 21, 2023, 08:14:08 AM »
THX
Jim Vigani
Offline Don Jenkins
« Reply #4 on: April 26, 2023, 06:38:17 AM »
I have had no problems with 2K clear. I wet sand the canopy with 2000 grit paper to remove any scratches or imperfections.  It will become opaque but the clear brings it back.
Don
Offline jfv
« Reply #5 on: April 27, 2023, 06:47:38 AM »
Thanks Don.  Just what I was thinking.  Very nicely done!
Jim Vigani
Offline Ara Dedekian
  • Ara Dedekian
« Reply #6 on: April 27, 2023, 02:14:35 PM »
       Jim,
         This post could be a lifesaver for me. I tried for a quick, durable, dope-less finish (practice for the next C/L build) and put a LOT of time into finishing and painting the RC Herr Aquastar in the photo. I used thin cyano to fill the grain and seal the wood, applying it and quickly toweling it off, just like resin. No waiting for things to cure before sanding. Some areas were covered in silkspan and others were left bare; no difference in the ready-for-paint surfaces. Paint was Petit Easypoxy marine paint. After all that, it's now a mobile hanging from my shop ceiling.
         My dilemma is the molded plastic windscreen and windows. The colors are Testors plastic model enamel and right under the engine. It will surely get doused with raw fuel. Converting to electric would require a complete redesign and rebuild.
        So, will a layer of 2K save the day? Weight isn't critical here and I've got scrap painted pieces to try it out on. Hope it works, float flying season is almost here.
     Ara
« Last Edit: April 27, 2023, 02:38:19 PM by Ara Dedekian »
