  • July 18, 2025, 01:38:06 AM
Author Topic: .02 carbon veil attached with water based Minwax poly??  (Read 4318 times)
Offline bruce finley
« on: December 22, 2014, 08:57:42 AM »
Anybody tried this vs traditional dope method?
Re: .02 carbon veil attached with water based Minwax poly??
« Reply #1 on: December 22, 2014, 01:45:35 PM »
Yea, once. Minwax doesn't fill very well.
« Reply #2 on: December 22, 2014, 02:50:49 PM »
Minwax + talc seems to make an OK sealer, if you're not too enthusiastic with the talc (too much and you get adhesion problems).
Given my experience with Minwax over silkspan I'd use it again for a not-too-critical finish, but if I wanted to be serious about things I'd use dope.
Offline Frank Simpson
« Reply #3 on: December 22, 2014, 05:20:20 PM »
What are you building Bruce???
Frank S.
« Reply #4 on: December 22, 2014, 05:23:09 PM »
Looking at the Brad Walker article on finishing....
http://flystunt.com/ARTICLES/FMFINISHINGARTICLE.htm
but instead of silkspan, using the carbon veil......
« Reply #5 on: December 22, 2014, 05:40:49 PM »
Good to hear from you Frank!!!  Finishing up a Pathfinder ARC
We need to get together
Frank S.
« Reply #6 on: February 06, 2015, 05:27:49 PM »
Great article just copying so I can find it later. One thing it doesn't mention, I put 2 coats of nitrate dope thinned 50/50 on the bare wood before water based polycrylic and you'll get less swelling in the grain.
« Reply #7 on: February 06, 2015, 08:49:46 PM »
You're right on there...
Water based worked for me.  Trying now to finish it up. ::)
« Reply #8 on: February 08, 2015, 10:30:12 PM »
Thought somebody might be going nuts looking for .02 CF veil, when there is no such thing. It's actually .2 oz, .3 oz, or .5 oz/sq. yard. I have .3 and .5 oz.  D>K Steve
« Reply #9 on: February 14, 2015, 11:29:32 AM »
I wouldn't recommend polycrylic and silkspan over open bays.  It cures to a very hard, brittle finish leading to many punctures.
PhilC
« Reply #10 on: February 15, 2015, 10:14:41 AM »
PhilC
Hi Phil,
I put on two coats of thinned nitrate on the bare wood, then used the polycrylic to attached the carbon veil, then used more dope over the polycrylic to attach the POLY SPAN on wings and tail areas--no silkspan used or PC over covering, just used the Minwax polycrylic to attach the carbon veil to solid balsa parts.  then used regular butyrate dope on top coats...
 It seemed to work well for me. I'd use it again.  D>K
Bruce
