  • June 14, 2025, 03:54:26 PM
Author Topic: Using Polyspan  (Read 3780 times)
Online James Mills
Using Polyspan
« on: February 18, 2009, 06:16:06 PM »
I'm ready to start the finish (again) on my Tempest after the paint pulled up.  I ended up removing all the covering off the bays, used polyspan first time.  Will I have any problems with the wing warping using polysan again or should I use silkspan?  The wing was built in Bob Hunts jig so it (the wing) started out straight and want to keep it that way.
James
AMA 491167
Re: Using Polyspan
« Reply #1 on: February 19, 2009, 09:00:13 AM »
In my experience Poly-span will not pull as much as silk when its shrunk.  DOC Holliday
Online James Mills
Re: Using Polyspan
« Reply #2 on: February 19, 2009, 06:58:23 PM »
Doc,
When you talk about "silk" do you mean silk or silkspan?  Are you going to St. Louis this weekend?
James
AMA 491167
