  • July 16, 2025, 02:53:14 PM
Author Topic: World Champs stunter?  (Read 2351 times)
Online Bill Hummel
« on: February 03, 2015, 09:31:57 AM »
Could someone tell me what stunter Rich Kornmeier from Germany was flying at the recent World Champs?  Nice looking ship, "old ST 60" technology!
Thanks for any help with this.
ama 72090
Re: World Champs stunter?
« Reply #1 on: February 03, 2015, 10:26:29 AM »
Hi Bill,
I would like to know that, too.
Online Lauri Malila
« Reply #2 on: February 03, 2015, 11:30:09 AM »
Isn't it Igor's design, Max? Seems to be very similar to Max Bee. L
« Reply #3 on: February 03, 2015, 12:49:58 PM »
Hi Lauri,
That does seem to come to mind, but i thought he was also using Igor's electric set up.  I guess Richie just hasn't become comfortable with it. (??)
Online Igor Burger
« Reply #4 on: February 03, 2015, 01:30:06 PM »
I am not sure which model it is, probably we are speaking abou yellow top Marshall? ... I think so, he has also its twin red top Marshall which he flew in past years. I designed those models for his hand some 10 or 12 years ago when I met his daddy, and it is basically MAX (the first one with 45 deg tilted engine http://www.netax.sk/hexoft/stunt/images/mRim00014.jpg ) modified for inverted ST 60 motor (little modified fatter fuselage). During time he had also modiffication with wing tip with shorter chord redesigned by Alex Schrek for his Extra like model which also uses aerodynamics from Max but different fuselage, but I think it was not best modiffication for such model.
Max itself had several versions:
Max ...  orriginal version with Os Max .46 LA with pipe (that why it got name Max)
Max II ... identical to Max, but logartithmic unit on flaps
Max 60 ... clone of Max for Richard and then used by several other 4-2-4 flyers
Max Bee ... my so far the last design cloned from Max II with new improved fuselage
So ... I think we are speaking about older Max 60 called Marschal with TL ST60 ... Richard told us that he decided to fly TL ST60, just for memory of Tom. If I can judge, Richard can fly well both electric and ST60 versions, I do not think that powertrain can have too much influence to flyer ability especially in relatively good conditions in Poland ... IF WORKS WELL ... and all Richards ST60 which I saw in his models worked well. As far as I know he has many of them and he was simply able to select and master those which served well. May be difficuld wind and turbullence will change situation but it was not the case, 3 years ago he decided to use my electric because he saw that it has good reliability especially in hard wind and we know fields here around notoric for strong constant wind :- ))) ... close to Atlantic or high in Alps.
« Last Edit: February 04, 2015, 12:43:01 PM by Igor Burger »
Offline Russell Bond
  • Bandolero
« Reply #5 on: February 03, 2015, 02:57:12 PM »
I spoke to Rickie at the World's and he said he liked the electric, but hasn't had enough time on it.
Also, he wanted to fly the ST 60 at Poland as he dedicated the flights to Tom Lay.
He had written on his wing; "Dedicated to my friend Tom Lay."
Bandolero
Online Howard Rush
« Reply #6 on: February 03, 2015, 03:53:41 PM »
Here's the airplane:
Online Igor Burger
« Reply #7 on: February 04, 2015, 01:36:28 AM »
Yes that is, and it has also red top twin :- ))
https://flic.kr/p/8o2c2T
https://flic.kr/p/6KiYDx
https://flic.kr/p/8oAPWj
(sorry that page does not allow linking pictures ... or at least I did not find how)
Online Igor Burger
« Reply #8 on: February 04, 2015, 01:46:35 AM »
and here is drawing of max 60
« Last Edit: February 04, 2015, 02:33:13 AM by Igor Burger »
Online Bill Hummel
« Reply #9 on: February 04, 2015, 11:06:24 AM »
Thanks Igor and everyone else. The drawing says it all!
ama 72090
« Reply #10 on: February 04, 2015, 11:49:48 AM »
Thank you Igor for your wonderful generosity and willingness to share. A true Champion!!
« Reply #11 on: February 04, 2015, 12:22:08 PM »
Hi Igor, Thanks!
I will try what you suggested, maybe they can be convinced! :)
Thanks, again,
