  • July 17, 2025, 09:22:05 AM
Author Topic: Wing Warp  (Read 2080 times)
Offline Darrell Mims
Wing Warp
« on: September 21, 2006, 07:32:44 AM »
 8)   OK  which is better ,place a tab on a wing or try and re heat the covering on a wing that is covered with UltraCoat .  I have a Viking that has a noticeable warp and would like it to fly straight.
Offline RC Storick
Re: Wing Warp
« Reply #1 on: September 21, 2006, 07:34:43 AM »
Use a tea kettle on the stove and get it steaming. Twist warp out and re-shrink the covering. Works every time.
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Wing Warp
« Reply #2 on: September 21, 2006, 08:15:50 AM »
Steam works well with silkspan and dope but didn't think steam had much effect on a plastic covered wing, steam can't get to the wood through plastic. A helper and heat gun is all I have ever used and managed to take some pretty good warps out.
Re: Wing Warp
« Reply #3 on: September 21, 2006, 05:39:22 PM »
I'm not familar with Ultracoat usage.  I have taken out warps in moneycoated wings with a heat gun.  They always came back.............  maybe it's the 115* heat indexes here in the summer?????????????  y1  f~
Bill <><
Offline RC Storick
Re: Wing Warp
« Reply #4 on: September 21, 2006, 05:41:31 PM »
If you use steam to take the power out of the wood before re-shrinking the monokote it will not come back.
Re: Wing Warp
« Reply #5 on: September 22, 2006, 04:40:59 AM »
 8)  I like the idea of the steam ! But how do you get it on the inside?  Hmmmmmmmmmmmmm
Offline Ralph Wenzel (d)
Re: Wing Warp
« Reply #6 on: September 22, 2006, 04:53:56 AM »
Simple - Move to the Gulf Coast! Everything is automatically "steamy". Houston wouldn't be half the city it is if not for Willis Carrier!
Ralph Wenzel
AMA 495785 League City, TX
Offline RC Storick
Re: Wing Warp
« Reply #7 on: September 22, 2006, 05:24:39 AM »
Trust me it will get inside. I have done this a lot.
Offline W.D. Roland
Re: Wing Warp
« Reply #8 on: September 22, 2006, 10:27:24 AM »
sometimes i have had to twist and shrink an opposite warp into wing and let sit a few days and see where it comes back to--and do it agin when nessary
have also used weights on t.e. and blocks/books/whatever under l.e. or spar and let sit afew days or longer
if you will ship it to me i will expose it to our natural high humidity and send it back ready to straighten!
steam works---never tryed it through plastic---the poors must be larger than i thought.
have used weights on elevator and let sit untill unweighted its straight----if it comes back i do same until it is same amount in other direction and let sit a few more days to see if it comes back straight.
 piping steam through leed outs or weight box should limber things up------might need weeks allow moisture to leave and should probably be jiged straight for that time
its been raining here off and on all week----sometimes humidity is lower when raining but just wait till the sun comes out!  n~
David
David Roland
51336
Offline Tom Perry
Re: Wing Warp
« Reply #9 on: September 22, 2006, 10:38:09 AM »
Don't forget that you can use the exaust from your airplane hauler at the field.  Very effective and getting cheaper with the price of gas comming down.   **)
Tight lines,
Tom Perry
 Norfolk, Virginia
Re: Wing Warp
« Reply #10 on: September 22, 2006, 06:55:40 PM »
8)  I forgot to mention this is a Viking and it's the outboard wing panel.   Anyway i will try and warp it the other way and hold it there to see if it will stay straight. . Thanks
